instanteous velocity
by eplymale3043
Tags: instanteous, velocity
eplymale3043
eplymale3043 is offline
#1
Sep4-08, 07:47 PM
P: 20
If an arrow is shot upward on the moon with a velocity of 59 m / s, its height in meters after t seconds is given by h = 59(t) - .83(t). Find the instantaneous velocity after one second.
2. Relevant equations
3. The attempt at a solution
h = 59(1) - .83(1)2
h = 58.17
h = 59(1.0000001)- .83(1.0000001)2
h = 59.0000059 - 0.8300001660000083
h = 58.1700057339999917
v = 58.1700057339999917 - 58.17 / .0000001
v = 57.339999917
thats as far as i get. i think the instant vel would be 57.3 m / s because it wont take the answer 57 or 57.5.
can someone help me?
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
Hootenanny
Hootenanny is offline
#2
Sep4-08, 07:53 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Quote Quote by eplymale3043 View Post
h = 59(1) - .83(1)2
h = 58.17
v = 57.339999917
Welcome to PF eplymale3043,
Since you've posted this in the calculus forums, I'm guessing that we should use calculus. So, what is the definition of instantaneous velocity, or velocity in general?
eplymale3043
#3
Sep4-08, 07:56 PM
P: 20
The speed at which an object is moving at any given time. right?
Hootenanny
#4
Sep4-08, 08:02 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Speed and velocity are two different quantities, but that's not what I was getting at. What is the definition of velocity in terms of distance and time?
eplymale3043
#5
Sep4-08, 08:05 PM
P: 20
v =[tex]\Delta[/tex]d/[tex]\Delta[/tex]t
Hootenanny
#6
Sep4-08, 08:09 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Correct, that would be the average velocity. For instantaneous velocity one would take the limit (substituting d for h for clarity):
[tex]v=\lim_{t\to0}\frac{\Delta h}{\Delta t} = \frac{dh}{dt}[/tex]
Do you follow?
eplymale3043
#7
Sep4-08, 08:11 PM
P: 20
Yes, so far.
Hootenanny
#8
Sep4-08, 08:13 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Yes, so far.
Now it's your turn to do some work. You are given h(t) in the question, all you need to do is find h'(t) and then plug in the numbers.
eplymale3043
#9
Sep4-08, 08:21 PM
P: 20
h'(t) meaning the inverse?
Hootenanny
#10
Sep4-08, 08:30 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
h'(t)
meaning the first derivative of h with respect to t. As I said in my previous post, velocity is defined as the rate of change of displacement with time.
eplymale3043
#11
Sep4-08, 08:35 PM
P: 20
Quote Quote by Hootenanny View Post
h'(t)
I'm sorry, I dont understand what you mean.
Hootenanny
#12
Sep4-08, 08:43 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
You are given h(t), which is a function describing how the height [displacement] of the arrow varies with time. Velocity is defined as the time derivative of displacement (height in this case), hence you need to take the derivative of h(t) with respect to t. In other words evaluate:
[tex]\frac{dh}{dt} = \frac{d}{dt}\left(59t - 0.83t^2\right)[/tex]
Does that make sense?
eplymale3043
#13
Sep4-08, 08:50 PM
P: 20
Yes, that makes alot more sense.
so, basically. I need to plug in the change in height for dh and change in time for dt.
then solve? im still not sure what d by itself it.
Hootenanny
#14
Sep4-08, 08:52 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
No, you need to take the derivative of h(t) and then plug in the numbers. You are studying calculus aren't you?
eplymale3043
#15
Sep4-08, 08:56 PM
P: 20
Yes, but I'm really lost.
How would I find the derivative?
Hootenanny
#16
Sep4-08, 08:59 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
There are plenty of resources available on the internet regarding calculus, but I would suggest that you sit down a read the first few chapters on differentiation from your textbook. I'm more than happy to help you though this problem, but there is little more than can be done without knowledge of differentiation.
eplymale3043
#17
Sep4-08, 10:03 PM
P: 20
After studying the chapter and doing some research in my calculus book, I have calculated that the velocity at 1 second is 57.34 m / s.
Does this sound right to you?
Hootenanny
#18
Sep5-08, 02:13 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Sounds spot on to me
Register to reply
Related Discussions
relationship between current, drift velocity and thermal velocity General Physics 3
velocity profile from 3d velocity space data General Math 3
Is the velocity of a bunsen burner flame proportional to the cold flow velocity? Advanced Physics Homework 0
Relationship of velocity of an electron/velocity of proton to....mass ratio Introductory Physics Homework 2
Given an initial position and velocity of a receiver, find the velocity of a ball Introductory Physics Homework 7
