Tidal forces and geodesic deviation: a principle question
The discussion revolves around the relationship between tidal forces and geodesic deviation in the context of general relativity and Newtonian physics. Participants explore the implications of comparing these two concepts, particularly focusing on the assumptions of flat versus curved spacetime and the mathematical consistency between the two theories.
  • Some participants question how tidal forces, which assume flat spacetime, can be compared to geodesic deviation, which assumes curved spacetime.
  • There is a discussion about the nature of separation vectors in curved spacetime and whether geodesic deviation can exist if only local flatness is considered.
  • One participant notes that the tidal forces equation involves second-order derivatives, suggesting a non-local aspect, while geodesic deviation is also linked to second-order derivatives.
  • Concerns are raised regarding the differences in parameters used in the equations for geodesic deviation (proper time) and tidal forces (regular time), questioning the validity of direct comparisons.
  • Another participant highlights the issue of spatial contractions when transitioning between reference frames, particularly between Newtonian and Lorentzian frameworks.
  • Some argue that the relationship between Newton's and Einstein's theories is inconsistent, with Newton's theory being an approximation of Einstein's, yet they express curiosity about how Newton could arrive at accurate measurements despite his assumptions of flat space and separate time.
  • There is mention of the need for a scalar product or metric to interpret mathematics in both Newtonian and general relativity contexts, raising questions about the operational definitions of distance in each framework.
Participants express multiple competing views regarding the comparison of tidal forces and geodesic deviation, with no consensus reached on the validity of the comparisons or the implications of the differing assumptions about spacetime.
Limitations include unresolved assumptions about the nature of spacetime, the dependence on definitions of distance and metrics, and the implications of using different coordinate systems in the analysis.
tsahi
hi all,
i kind of have a black hole regarding my understanding of the consistensy of
tidal forces and geodesic deviation analysis. one can determine some coefficients
of the riemman tensor from the tidal forces equations, by getting to a form
that is like the form of the geodesic deviation equation.
however, in the tidal forces analysis we assume that spacetime is flat,
and in geodesic deviation analysis we assume spacetime is curved. how come
we can than compare the two equations? that is, in flat space time
we have a bilocal meaning to vectors, where in curved spacetime we have a local
meaning?
i will sharpen the question:
how can one even have a notion of a separation vector in curved spacetime?
if we are only looking locally where the spacetime is flat, then there should
be no geodesic deviation.
A first order derivative is more non-local than a zeroth order, because it compares two positions. Similarly, a second order derivative is more non-local than a first order derivative. The tidal forces equation is not local in the sense that it has a second order derivative. Also, the tidal forces equation does not occur in flat special relativistic spacetime - it occurs in flat Newtonian spacetime with gravity - so it is curved. Curved spacetime is locally flat by the equivalence principle, but only to first order. The Riemann tensor is also a second order derivative.
yes, i understand,
but what is it that enables us to regard spacetime as flat (Newton, tidal forces analysis) and curved (geodesic analysis) at the same time?
Two objects of mass change their relative speed as if they accelerate towards each other, however their proper acceleration is zero, hence spacetime cannot possible be flat. Newton apparently did not think of that at the time he developed his theory.
Space is simply an arbitrary slice of spacetime so whether that slice is curved simply depends on how you wish to slice it. :)
i did not understand the last explanation. proper acceleration?
tsahi said:
yes, i understand,
Magic.:smile: Your suspicion is well justified! Newton's theory and Einstein's theory are 2 completely different conceptions of gravity. In a mathematically consistent theory, which statements we regard as assumptions and which are derived is a matter of taste. However, Newton's theory and Einstein's theory are not mathematically consistent. Einstein's theory cannot be derived from Newton's theory. Newton's theory can be derived only approximately from Einstein's theory. Even in the weak field situation, Einstein's theory predicts perihelion precession, but Newton's doesn't. The relationship between tidal forces and geodesic deviation should be seen as a way of transitioning between two extremely useful but inconsistent theories.
There's a useful analogy I learned from the Feynman lectures. Newtonian mechanics has 3 equivalent viewpoints: Newtonian, Lagrangian and Hamiltonian. You can pick any viewpoint you like. But in generalizing to quantum mechanics, (trying to guess the more correct theory to which Newton's theory is only an approximation), only the Hamiltonian and Lagrangian viewpoints work. Note that till this day we do not know why classical reality emerges from our supposedly more correct quantum theory!
Around 1910, Einstein knew Newton's theory was right, but not completely right. So he was in a similar situation as to where we are now with respect to his equations (he had some excellent competitors, and the choice between them was based on experiment, not Einstein's genius). Which aspects of his theory should we use to transition to the new more correct theory?
As summarized by Gu and Wen: There are many different approaches to quantum gravity based on different principles. Some approaches, such as loop quantum gravity, stress the gauge structure from the diffeomorphism of the space-time. Other approaches, such as superstring theory stress the renormalizability of the theory. In this paper, we follow a different rule of game by stressing finiteness and locality.
Or Padmanabhan: The quantum description of spacetime is likely to be as different from the classical description, as the atomic description of a solid is from the macroscopic continuum description of a solid. The latter uses concepts like density, stress and strain, bulk flow velocity etc., none of which has much relevance in the microscopic scale; the quantum description of molecules in a solid cannot be obtained by quantising the classical macroscopic variables. ... Quantisation of the metric has as much relevance — in this paradigm — as quantising, say, the density and bulk flow velocity of a solid with the hope of obtaining a quantum theory of molecules.
http://arxiv.org/abs/gr-qc/0606100
http://arxiv.org/abs/gr-qc/0408051
all that is good and well. but when you look at the 2 equations,
the geodesic deviation has a proper time of the fiducial geodesic as parameter,
the tidal force has
regular time as parameter. these parameters are not the same thing.
so how can we simply compare the coefficients there to get riemann?
also, the comparison does not seem to take under account the fact the there are spatial contractions when moving to the reference frame of the fiducial particle...
tsahi said:
all that is good and well. but when you look at the 2 equations, the geodesic deviation has a proper time of the fiducial geodesic as parameter, the tidal force has
regular time as parameter. these parameters are not the same thing. so how can we simply compare the coefficients there to get riemann?
The assumption is made that the speed is small, so proper time and coordinate time are very nearly the same.
We are only using one coordinate system here. Length contraction only occurs when comparing lengths measured in two different coordinate systems.
but we have two - lorenz of the fiducial particle and Newtonian, and i meant generally
the not trivial lorentz transformation between coordiate systems.
my problem lies in the very ability of Newton to think space is flat and time as separate.
how come the measures came out right? what were his rods and clocks?
Yes, there seems to be something strange going on here. We cannot interpret our mathematics unless we have a scalar product or metric which encodes our operational definition of distance. In Newtonian physics, the metric is fixed, and so we always have an interpretation of our coordinates. In GR, the metric is not fixed, and we cannot interpret our coordinates until we have a metric. Yet here it seems that we are interpreting our coordinates to arrive at the metric.
I suppose a more rigourous way would be to take a well-interpreted static solution to GR such as the Schwarzschild solution, take the weak field and low velocity limit, and see that we approximately recover Newtonian tidal forces.
I am now recalling that Rindler does give a procedure for measuring the metric locally (Relativity: Special, General, and Cosmological, 2006). I don't remember what it is though.:confused:
  • · Replies 76 ·
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 30 ·
