| Thread Closed |
densely defined operators of Fock space |
Share Thread |
| Sep9-08, 07:41 PM | #1 |
Could someone prove the following (if it is precisely correct):
Since Fock space is the closure of the finite linear span of finite excitations of the vacuum state $\Omega$, then the operator $\hat{O}$ is densely defined if and only if $\hat{O} \Omega$ has finite norm. Or more generally, an operator is densely defined on a separable space if it is defined on a given single vector in that space. thanks |
| Sep10-08, 09:02 PM | #2 |
Recognitions:
answered yet I'll have a go... (BTW, $....$ doesn't work here for latex strings. I've fixed them below. Click on any one of them to see the latex source, and a link to some latex info relevant to PhysicsForums.) cyclic operations of the annihilation and creation operators upon a distinguished vacuum vector (and a subsequent closure). Under this construction the a/c operators form an irreducible set, meaning that *any* operator on the Fock space can be expressed as a sum of polynomials of these operators. (Since you only want "densely defined", polynomials are enough -- you don't need to worry about infinite series and associated existence issues.) Then you take an arbitrary product of a/c operators. Eg, for a quadratic in the creation operators it might be something like: [tex] O_2 ~:=~ \int dp dq ~ f(p,q) a^*(p) a^*(q) [/tex] More generally, there might also be annihilation operators but you can use the CCRs to normal-order them, and if the result is any naked delta fns (which cannot be integrated away) then such an operator doesn't give a finite-norm vector when acting on the vacuum. I think that's enough to do the proof in one direction (though you'll have to clean it up and fill in more details). Once you've seen it in one direction you can probably figure out the reverse direction. And if I've got anything wrong in the above, maybe someone else will enjoy correcting it. :-) assumptions (such as the cyclicity of the vacuum and maybe some other stuff). "Separability" in this context only means the space has a countable orthonormal basis, so you've got to show that the operator acting on any basis vector results in a finite-norm vector. (Actually, that's kinda what I did above in a clumsy way for the Fock, since one gets a countable basis there by acting on the vacuum with products of creation operators.) HTH. |
| Oct5-08, 08:43 PM | #3 |
Thanks for the response
sorry i've been a bit busy to reply. Yes, a lot of operators have the same action on a given vector (in a separable space) but some will give non-normalizable vectors when acting on other vectors - unless addition assumptions are made. I didn't read the paper carefully anough, te separable space in question is isomorphic to Fock space Thanks julian |
| Thread Closed |
Similar discussions for: densely defined operators of Fock space
| DFT/hartree Fock calculations | Atomic, Solid State, Comp. Physics | 20 | ||
| Multiconfiguration Hartree-Fock Method | Atomic, Solid State, Comp. Physics | 6 | ||
| Fock state | Quantum Physics | 9 | ||
| Hilbert/Fock space spanned by non-interacting states | Quantum Physics | 13 | ||
| Hatree fock formalism | Atomic, Solid State, Comp. Physics | 3 | ||
