Is there any way to find the distance between a nucleus and its electrons?
  • Context: Undergrad
  • Thread starter Thread starter durkadurka282
    Electrons Nucleus
The discussion revolves around the concept of finding the distance between the nucleus and electrons in an atom, specifically focusing on carbon. Participants explore the implications of quantum mechanics on atomic structure and the limitations of classical models.
  • One participant asserts that classical notions of "distances" in atoms are misleading, emphasizing the probabilistic nature of electron positions as described by the Schrödinger equation.
  • Another participant suggests that solving the Schrödinger equation provides the probability of finding an electron at a certain radial distance from the nucleus, referencing hydrogen as an example.
  • There is mention of the possibility of an electron being found inside the nucleus with a non-zero probability, leading to discussions about phenomena like inverse beta decay.
  • Some participants discuss the implications of anti-symmetric wave-functions for fermions, arguing that they imply zero probability at the nucleus, while others challenge this by pointing out that certain orbitals have maximum probability density at the center.
  • One participant highlights the need for a subjective definition of "radius" when discussing orbitals, indicating that the concept is not straightforward.
  • There are multiple references to external resources for visualizing atomic orbitals and their properties.
Participants express differing views on the implications of wave-functions for electron positions, particularly regarding the probability density at the nucleus. The discussion remains unresolved with competing interpretations of quantum mechanics and atomic structure.
Limitations include the dependence on the definitions of terms like "distance" and "radius," as well as the unresolved nature of the mathematical implications of wave-functions in relation to electron capture and orbital shapes.
durkadurka282
If possible, how can you figure out the distance between the nucleus and the electrons of an atom?
Specifically, a carbon atom?
There is no such things as "distances" in atoms, in the way you think. The classical picture of a nucleus having electrons around it as planets is wrong.
What you do is that ou solve the so called Shrodinger eq for the system, which gives you the probability to find an electron of a certain state at a certain radial distance from the nucleus. For example hydrogen, which you can solve with pen and paper:
http://panda.unm.edu/Courses/Finley/P262/Hydrogen/WaveFcns.html
So an electron can be INSIDE the nucleus with a non-zero probability, and also interact with a proton with a certain probability, then you get a thing called inverse beta decay:
http://en.wikipedia.org/wiki/Electron_capture
If you want to find out how to get radial wave functions for carbon, then wait til this thread is beeing moved to atomic physics forums, since this is nuclei and particle physics forum ;-)
Note that the answer is given under the label "Figure 4" in this link. You want the maximum of [itex]r^2 e^{-r/a_0}[/itex]. If you work it out, please tell in the thread.
Also you can calculate the probability for the electron of the Hidrogen to be inside the nucleus. And instead Carbon, you can try to discuss Berilium first. Actually I find surprising its ability to decay via EC.
allright, thanks for the help!
May I also point out that every fermion has an anti-symmetric wave-function which by definition means that it has zero chance of being at the origin, ie. the nucleus.
The nucleus does have structure, albeit a lot less than the atom's dimensions. Thus the reaction cross-section between a nucleus and an associated fermion will be miniscule. If a nucleus could hold on to a boson (impossible AFAIK) then its wave-function would have to be non-zero at the origin.
Somehow the deduction through anti-symmetric wave-functions is flawed, because 1S, 2S etc orbitals have the maximum probability density right at the centre.
P, D and all orbitals with a momentum have zero probability density a the centre. This is why electron capture always swallows S electrons (and almost always 1S electrons, whose orbital is denser at the centre). Observed in subsequent emission spectra, as electrons rearrange around the nucleus.
Nice pictures at http://www.webelements.com/ - useful site anyway, which sends to http://winter.group.shef.ac.uk/orbitron/
(Carbon's) 2P is there http://winter.group.shef.ac.uk/orbitron/AOs/2p/index.html
2S there http://winter.group.shef.ac.uk/orbitron/AOs/2s/index.html
and 1S there http://winter.group.shef.ac.uk/orbitron/AOs/1s/index.html
This may not be obvious from Orbiton's pictures, but a radius is a fuzzy notion for an orbital, and you'll have to decide some kind of subjective definition to get a figure.
Just because it is a spherical wave-function it doesn't mean that there is a maximum at zero. The s orbital is zero at the origin or it isn't a fermion.
Plot the radial solution [itex]R_{nl}[/itex] function for l=0 from the Schrödinger equation for a hydrogenic atom, and then come back and tell us that it is zero at the origin.
Zz.
fermions have antisymmetric wave function w.r.t particle exchange, you should not mix this concept into wavefunctions of single fermionic wavefunctions.
Solve the Shrödinger eq för the hydrogen atom, and you'll get the wavefunctions and the radial parts are non zero at origin for S orbitals. (the angular part are alos nonzero since spherical harmonics is a constant for L = 0)
"w.r.t particle exchange,"
Yup, sorry, wrong end of the stick.
