Electricity and the shortest path
  • Context: High School
  • Thread starter Thread starter ShawnD
    Electricity Path
The discussion revolves around the dangers of electrical devices falling into bathtubs, exploring the mechanisms of electric shock, the myths surrounding electrocution, and the conditions under which such incidents may occur. Participants engage in both theoretical and anecdotal reasoning regarding the effects of electricity in water and the safety of using electrical appliances near water.
  • Anecdotal experiences
  • Some participants argue that electricity follows all paths, meaning that current can flow through water and a person, not just between wires.
  • Others suggest that the resistance of water and the human body is low enough that significant current can flow, leading to dangerous situations.
  • A few participants claim that the idea of electrocution from a radio in a bathtub is a myth, comparing it to the myth of electrocution from a car battery.
  • Some anecdotes illustrate personal experiences with electrical shocks and near-misses, emphasizing the unpredictability of such situations.
  • Concerns are raised about the reliability of circuit breakers and the potential for severe injury or death if safety mechanisms fail.
  • A participant humorously suggests a dangerous experiment to test the effects of multiple electrical devices in a bathtub, highlighting the absurdity of the idea.
Participants express a mix of beliefs, with some asserting that electrocution from a radio in a bathtub is a myth, while others maintain that it is indeed possible under certain conditions. The discussion remains unresolved, with competing views on the dangers of electricity in water and the reliability of safety mechanisms.
There are unresolved assumptions regarding the effectiveness of circuit breakers, the specific conditions under which electrocution may occur, and the definitions of safety in electrical contexts. The discussion also reflects a range of anecdotal experiences that may not be universally applicable.
Individuals interested in electrical safety, the physics of electricity, and the myths surrounding electrical hazards may find this discussion relevant.
ShawnD
Why do people die when a radio falls into the tub they are bathing in?
The wires only have a voltage relative to each other. Red has voltage relative to black, but not the water or the person. Black has voltage relative to red, but not the water or the person. Electricity always follows the path of least resistance, so shouldn't the electricity go straight between red and black instead of going through all the water and the person?
Electricity follows all paths. More current flows through the lower resistances, but some flows through all of it. Additionally, the black is just ground... the same as the pipes and the tub. To make it worse, you short circuit the plug, so you're pulling between 15 and 20 amps... usually 20 if it's a bathroom fixture that isn't GFCI or AFCI protected.
When you connect two resistors of different resistance in parellel, will current only flow through the resistor with lower resistance?
I is proportional to 1/R, and the resistance of "all the water and the person" is simply not high enough to make the current neglible. And I guess the reason they die is that they don't have time to climb out of the bath tub before the electric shock becomes critical, because as far as I know you lose most control over your muscles in these situations and they contract themselves. That's why when you touch a lamp, for example, to see if it's dangerous, you should touch it with the back of your hand rather than grab it. But I may well be wrong. :wink:
They don't. It's a myth created by Hollywood. It's similar to the myth that you can electrocute someone with a car battery.
What? You can't be serious.
What would make you doubt Krab? He's always been right before.
Everybody knows you can't shock somebody with a car battery, but the radio in the bathtub thing is somewhat believable.
The car battery situation I understand. My gripe is with the radio, like you suggested.
My wife has a hair dryer in our bathroom which has a "Do Not Remove" tage on it. The tag has a drawing of a bathtub and a hair dryer above it and a big red X over the entire pic. The text on the tag says :To Reduce Risk of Electrocution Do Not Use Near Water"
Kill you or not, I doubt it's in your best interest to throw any electric device into your bath tub.
Throwing a radio into the tub will probably trip the breaker before it has a chance to do any real damage.
If the break doesn't work properly, your house will probably start on fire :biggrin:
You can die if you have 20 amps go through you. But in the bathtub, most of the current will pass through the water (R~L/A, or think of it as the potential gradient across your body being small compared to some of the water near the electrical leads). So, even if you short the supply without tripping a breaker or fuse, you're only going to get badly zapped, at worst.
Note that this is very different from sticking metal wires into a the sockets of a power outlet - though if you hold both wires in the same hand, like chopsticks, you may only end up with a toasted hand.
Please don't try any of these things cause they are all extremely dangerous, and most are exceptionally stupid.
I actually stuck things in the wall before when I was like 5. Knife in either side then touch em; youch! Hopefully it didn't fug my heart.
Yeah, I tripped the circuits 3 times within about a year when I was little, nearly electrocuting myself, and understanding better than most at an early age how electricity works.
OK, let's do an experiment to find out.
First, let's get our hands on that ******* who beheaded Daniel Berg in Iraq. (BTW, I saw the ENTIRE video of the execution... most disturbing)
Next, let's give that ******* a bath since he likely hasn't had one since he was born.
Then, let's put in some pretty pink bubble soap just to piss him off.
Now, let's throw in a live connected radio, hair dryer AND T.V. and see what happens.
Of course, as good scientists, we will want to repeat the experiment several times.
In that experiment, if you used big wires and no fuses/breakers, the water would probably boil and he would die from the heat.
It is far from a myth created by anyone.
The breaker wil not trip (unless it is a groung fault breaker those with reset on it) and you are not only die but you will die cook.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 42 ·
  • · Replies 36 ·
  • · Replies 36 ·
