Zero degrees of freedom. Does it has any sense?
The discussion centers on the degrees of freedom of an upside-down rotating cone with a constant angular speed. Participants assert that if the rotation is restricted to a static axis, the system possesses no generalized coordinates to describe its movement. The conclusion drawn is that despite the cyclic nature of rotation, the system effectively has zero degrees of freedom due to the constraints imposed on its motion.
  • Understanding of rotational dynamics
  • Familiarity with degrees of freedom in mechanical systems
  • Basic knowledge of angular velocity and static axes
  • Concept of generalized coordinates in physics
  • Research the concept of degrees of freedom in rigid body dynamics
  • Explore the implications of constraints on motion in mechanical systems
  • Learn about generalized coordinates and their applications in physics
  • Investigate cyclic motion and its characteristics in rotational systems
Students of physics, mechanical engineers, and anyone interested in the principles of rotational dynamics and constraints in motion.
MiGUi
I was discussing with my friends that problem:
If we have a cone, upside down, rotating with angular speed constant, how much degrees of freedom, the system has?
Ok, I think that if the movement is restricted to rotate around a static axis, and the speed of rotation is constant, you don't have any generalized coordinate to describe the movement...
Is it possible? or even you have a generalized coordinate at last?
Thanks,
MiGUi
I would think that it has a cyclic 360 degree's of freedom.
No, the degrees of freedom is the number of coordinates you need to describe the movement.
14K
  • · Replies 33 ·
