Register to reply
Inertial Reference problem
by PhoenixRising
Tags: inertial, reference
Share this thread:
PhoenixRising
#1
Sep16-08, 03:43 PM
P: 3
You are conducting an experiment inside a train car that may move horizontally along rail tracks. A load is hung from the ceiling on a string. The load is not swinging, and the string is observed to make a constant angle of with the horizontal. No other forces are acting on the load. Which of the following statements are correct?
Statements include:
The train is an inertial frame of reference.
The train is not an inertial frame of reference.
The train may be at rest.
The train may be moving at a constant speed in a straight line.
The train may be moving at a constant speed in a circle.
The train must be speeding up.
The train must be slowing down.
The train must be accelerating.
Please help, and if you could, explain why as well. I am doing these as practice for an exam and would really like to lock down the concept.
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
edziura
#2
Sep16-08, 05:13 PM
P: 117
"and the string is observed to make a constant angle of with the horizontal"
The answers depend on whether this angle is 90 degrees (i.e., hanging vertically) or some other angle.
Should the word 'horizontal' be replaced with 'vertical'?
PhoenixRising
#3
Sep16-08, 05:34 PM
P: 3
it's a 45 degree angle from the horizontal, sorry :)
edziura
#4
Sep16-08, 06:03 PM
P: 117
Draw a free body diagram of the load. If F = ma indicates that a is 0, its inertial; if a is not 0, its not inertial. You should find that a not zero, and it is constant.
The load in moving and accelerating at the same rate as the train. Answer the question: Can an object be accelerating if its velocity is zero? Is an object tossed in the air accelerating at the peak of its path?
Can't be if its accelerating.
In this case, is its acceleration constant?
Nope.
Nope
Yep.
PhoenixRising
#5
Sep16-08, 06:28 PM
P: 3
Thank you, hard to wrap my head around it all sometimes.
Register to reply
Related Discussions
What is an inertial reference frame? Special & General Relativity 7
Inertial Reference Frame Special & General Relativity 15
Inertial Reference System General Physics 9
Inertial and Non-Inertial Frames of Reference Question Introductory Physics Homework 6
Inertial reference frames Special & General Relativity 2
