Statics: Varignon's Theorem
by physicsnewblol
Tags: statics, theorem, varignon
physicsnewblol
physicsnewblol is offline
#1
Sep17-08, 03:40 PM
P: 9
In general, how would you find the moment of a force given:
  • the magnitude of the force
  • two coordinates that form a line that contains the force vector
  • the pivot point
using Varignon's Theorem
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
PhanthomJay
PhanthomJay is offline
#2
Sep17-08, 07:47 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 5,961
Quote Quote by physicsnewblol View Post
  • the pivot point
I hope you looked up Varignon's theorem as it applies to moments. It essentially states that the moment of a force about a pivot point is equal to the sum of the moments of the components of that force about the point. You must show an attempt at your solution for further assistance.
physicsnewblol
#3
Sep18-08, 08:33 PM
P: 9
Nevermind, I was doing the problem correctly but the book listed an incorrect answer. To answer my own question, you simply choose one of the points as the application point of the force. You then proceed to find the distance vector which is essentially the application point written in vector form. Take this vector and find the cross product with the vector representation of the force.
The problem is number 31 in Engineering Mechanics: Statics, by J. L. Meriam and L. G. Kraige. The correct answer is 518 N*m
PhanthomJay
#4
Sep20-08, 10:29 AM
Sci Advisor
HW Helper
PF Gold
P: 5,961
That method of M = rF sin theta will yield the correct answer, but that is not applying Varignon's theorem, which often simplifies the solution.
Register to reply
Related Discussions
Statics Statics Statics Introductory Physics Homework 4
greens theorem and cauchy theorem help Calculus & Beyond Homework 4
Gauss' Theorem/Stokes' theorem Advanced Physics Homework 2
Gauss's Divergance Theorem and Stokes's Theorem Classical Physics 1
statics Introductory Physics Homework 9
