miller index problem
by Carolyn
Tags: index, miller
Carolyn
Carolyn is offline
#1
Sep21-08, 03:38 AM
P: 37
Can somebody tell me what is the miller index for the tilted plane?
Is it (102) or (112)?
Nothing seems to fit...
I wonder if we can even describe it with miller index?
Please download the picture here in pdf format:
http://www.megaupload.com/?d=F8J344BH
Thanks!
Phys.Org News Partner Physics news on Phys.org
Researchers develop scalable methods for manufacturing metamaterials
Researchers find tin selenide shows promise for efficiently converting waste heat into electrical energy
After 13 years, progress in pitch-drop experiment (w/ video)
Carolyn
Carolyn is offline
#2
Sep21-08, 03:39 AM
P: 37
or see the attached file if you can...
Mapes
Mapes is offline
#3
Sep21-08, 10:55 AM
Sci Advisor
HW Helper
PF Gold
Mapes's Avatar
P: 2,532
Every plane has a Miller index. A common way to find the Miller index for a plane in a cubic system is to take the reciprocal of the axis intercepts and normalize the result so it contains only integers. Negative intercepts are treated by putting a bar over the number. For example, the y-intercept in your figure is at -1.
Carolyn
Carolyn is offline
#4
Sep21-08, 12:57 PM
P: 37
thanks for the reply. But could you explain why is the y intercept for the triangular plane -1? it does not seem to intersect with the y axis?
Mapes
Mapes is offline
#5
Sep21-08, 03:52 PM
Sci Advisor
HW Helper
PF Gold
Mapes's Avatar
P: 2,532
The plane continues on to infinity; if you follow the line in the y-z plane, you'll see that it (and therefore the plane) intersects the y-axis at -1. Use the same approach for the other axes.
Carolyn
Carolyn is offline
#6
Sep21-08, 04:18 PM
P: 37
um..so are you saying that I can extend the vector so it eventually intersects with the y-axis?
so the miller index should be (1-12)?
Mapes
Mapes is offline
#7
Sep21-08, 04:28 PM
Sci Advisor
HW Helper
PF Gold
Mapes's Avatar
P: 2,532
Yes; a [itex](1\bar 1 2)[/itex] plane (a member of the family of [itex]\{112\}[/itex] planes), with surface normal vector [itex][1\bar 1 2][/itex] (a member of the family of [itex]\langle 112\rangle[/itex] directions).
Carolyn
Carolyn is offline
#8
Sep21-08, 04:31 PM
P: 37
But, for example, this picture is also (1,-1,2). so are they a family?
Mapes
Mapes is offline
#9
Sep21-08, 04:32 PM
Sci Advisor
HW Helper
PF Gold
Mapes's Avatar
P: 2,532
More than another member of a family; that's the same plane.
Carolyn
Carolyn is offline
#10
Sep21-08, 04:36 PM
P: 37
ok. I think I am getting it, thanks a lot.
Register to reply
Related Discussions
[SOLVED] Another Index of Refraction Problem!!!!!!!!!!! HELP! PLEASE Introductory Physics Homework 16
MATLAB index problem Math & Science Software 8
Second opinion for an Index Problem Set Theory, Logic, Probability, Statistics 2
Miller Index Question Introductory Physics Homework 6
Miller index Atomic, Solid State, Comp. Physics 16
