Gravitational Grand Prix: How is force calculated in relation to acceleration?
  • Context: High School
  • Thread starter Thread starter calisumrbby
    Gravitational
The discussion revolves around the calculation of force in relation to acceleration, specifically whether to use average or instantaneous acceleration. Participants explore the implications of these choices in different contexts, including time-varying forces.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant states that force is calculated as mass times acceleration, questioning whether to use average or instantaneous acceleration.
  • Another participant asserts that instantaneous acceleration should be used for calculating force.
  • A different participant explains that if the force is time-varying, the acceleration will also vary, suggesting that instantaneous force requires instantaneous acceleration, while average force can use average acceleration.
  • Another comment emphasizes that the choice of acceleration affects the force calculated, noting that using the change of acceleration results in a change of force, while using acceleration at a specific time yields force at that time.
Participants express differing views on whether to use average or instantaneous acceleration for force calculations, indicating that multiple competing perspectives remain in the discussion.
Participants highlight the dependence on the type of force being considered and the implications of time-varying forces, but do not resolve the nuances of these calculations.
calisumrbby
How do you calculate force? I know its mass times acceleration but do you use average acceleration or instantaneous acceleration at a certain point in time?
Force causes acceleration. If the force is time varying, so will be the acceleration. If you want to calculate the instantaneous force, you use the instantaneous acceleration, but if you only need the time averaged force, you can use the average acceleration.
As said above, it depends which force you want. if you use the change of acceleration, you get the change of force. If you use accerlation at time X, you get force at time X. I always wondered why they never taught that in my physics class (that your bringing more than just variables with your equations).
  • · Replies 29 ·
  • · Replies 33 ·
  • · Replies 51 ·
