How Far Must You Walk to Experience Silence Between Two Phase-Aligned Speakers?
The problem involves two phase-aligned loudspeakers emitting sound waves at a frequency of 688 Hz in an open field. The speed of sound is given as 344 m/s, and the task is to determine the shortest distance one must walk to reach a point of silence due to destructive interference of sound waves.
  • Participants discuss the calculation of wavelength and conditions for destructive interference, questioning the original poster's understanding of the interference principles. There is also a focus on the geometry involved in determining the distances to the speakers.
Some participants have provided clarifications regarding the conditions for destructive interference, emphasizing the need for a path-length difference that is a half-integer multiple of the wavelength. The original poster has acknowledged missing information about the distances between the speakers and their starting position, which has prompted further exploration of the problem.
Key information about the distances from the original poster to each speaker was initially omitted, which is crucial for solving the problem. The discussion also highlights potential confusion in the textbook explanation of interference.
Foxhound101
Imagine you are in an open field where two loudspeakers are set up and connected to the same amplifier so that they emit sound waves in phase at 688 Hz. Take the speed of sound in air to be 344 m/s.
What is the shortest distance d you need to walk forward to be at a point where you cannot hear the speakers?
f1= V/2L
lambda1 = 2L
So...this is what I did...
688 = 344/2L
L = .25
lambda1 = 2L
lambda = 2(.25)
lambda = .5
Destructive interference occurs at a distance that is half lambda. I said that the answer was .25 meters, but according to the program that is not the correct answer. So...where is my error? (It is always possible the program is wrong, but normally it is me) Please help me identify my mistake.
Unless I'm supposed to walk beyond one of the speakers...but that doesn't make sense either...
Well, using another formula...
lambda=V/f
lambda=344/688
lambda=.5
So I still believe that lambda is .5.
That is not really true. Review the part of your textbook or lecture notes that discusses interference more carefully. What is the actual condition?
"Destructive interference occurs when the path-length difference is...
r=(m+.5)*lambda
where m = 0, 1, 2, 3, ...
Constructive interference occurs when the path-length is...
r = m*lambda
where m = 0, 1, 2, 3, ..."
So...I still don't really understand. The book does not do a good job explaining this.
r=(m+.5)*lambda
Yes, that's it. The difference in the path lengths from you to each speaker should be a "half-integer" multiple of the wavelength ... i.e., (1/2)λ, (3/2)λ, (5/2)λ, etc. etc. In other words, (m+0.5)λ as the formula says.
You'll have to use some geometry to figure out where you can be, so that the distances from you to the two speakers differ by the minimum amount of λ/2 (= 0.25 m).
By the way, some things are not clear from your original post:
1. How far apart are the speakers?
2. What is your location, when you start to walk forward?
Woops...silly me. That information was in part A, which I had already answered and didn't include in the original post.
*restates problem*
Part A
If you are 3.00 m from speaker A directly to your right and 3.50m from speaker B directly to your left, will the sound that you hear be louder than the sound you would hear if only one speaker were in use?
YES
Part B
Okay, good.
At what locations can you be (in between the 2 speakers) so that your distance to 1 speaker is (1/2)λ, (3/2)λ, (5/2)λ, etc greater than or less than your distance to the 2nd speaker?
  • · Replies 19 ·
  • · Replies 27 ·
