Register to reply
Projectile, Range, Maximum Height, Time of Flight Problem
by Gimp Mask
Tags: flight, height, maximum, projectile, range, time
Share this thread:
Gimp Mask
#1
Sep21-08, 11:15 PM
P: 1
Your teacher tosses a basketball. The ball gets through the hoop. How long does it take the ball to reach its maximum height? How long does it take the ball to reach the hoop? What is the horizontal length of the shot? (Neglect air friction).
Initial velocity: 17 m/s
53 degree angle between the ball's initial position and the ground.
The height of the teacher is 2.576 m. (This is the ball's initial height.)
The height of the goal is 3.048 m. (This is the ball's final height.)
2. Relevant equations
Vf = Vyo + at
Vyo = VoSinΘ
3. The attempt at a solution
I solved the first part as follows:
Vyo = VoSinΘ
Vf = Vyo + at
0 = 13.5768 - 9.8t
-13.5768 = -9.8t
t = 1.3854s (Time to get to maximum height. This answer is correct.)
I'm having some trouble with the second and third part though. For the second part:
Vyo = VoSinΘ
d = Vyot + 1/2at^2
I subtracted the two heights (3.048m - 2.576m = 0.472m).
0.472m = 13.5768t + 1/2(9.8m/s^2)t^2
I then used the quadratic formula:
-13.5768 +- (square root of: ((13.5768^2) - 4(4.9)(-0.472))/(2)/(-0.472)
The answer I derived was not correct (28.4).
For the third part:
Xmax = 2Vo^2sinΘcosΘ/g
2(17^2)(sin53)(cos53)/9.8
The answer I derived was not correct (28.3).
Please help me if you can!
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
Mattowander
#2
Sep22-08, 09:03 PM
P: 159
For the second part, first calculate the time it takes the ball to reach maximum height, which you already found to be 1.4 seconds.
Next, calculate the maximum height it reached. From there, the object is falling the maximum height PLUS the .472 meter difference. Use that total height to calculate the total time. Because the object is simply falling from the maximum height, Vo is 0 and so it's not a quadratic equation.
Once you find this time, add that to the first time you got. This will give you the total time.
Once you have the total time, you can simply use S = VT to solve for the horizontal distance.
Hope that helps :)
Quote Quote by Gimp Mask View Post
Vf = Vyo + at
Vyo = VoSinΘ
Vyo = VoSinΘ
Vf = Vyo + at
0 = 13.5768 - 9.8t
-13.5768 = -9.8t
Vyo = VoSinΘ
d = Vyot + 1/2at^2
For the third part:
Register to reply
Related Discussions
Help with problem, only given maximum height and range Introductory Physics Homework 1
Projectile maximum range PLEASE HELP! Introductory Physics Homework 5
Find the maximum height and the range of the ball. Introductory Physics Homework 5
Firing a projectile, max height + flight time Introductory Physics Homework 13
Max height of a projectile equal to range? General Physics 3
