Ricci-Tensor from Riemann in higher dimensional flat space
  • Context: Graduate
  • Thread starter Thread starter wildemar
    Flat Riemann Space
The discussion revolves around the calculation of the Ricci-Tensor derived from the Riemann tensor in a higher-dimensional flat space, specifically extending the Robertson-Walker metric. Participants explore the implications of adding extra spatial dimensions and the associated scale factors.
  • One participant presents a line element for a flat space metric and attempts to calculate the Ricci-Tensor, providing specific Riemann tensor components.
  • Another participant expresses confusion about discrepancies in the calculations, particularly regarding the coefficients in the Ricci tensor expressions.
  • A later reply identifies that the components of the Riemann tensor are zero when all indices are identical, suggesting that this affects the calculations of the Ricci tensor.
  • The same reply also points out that the sums over indices must exclude terms where indices are identical, leading to adjustments in the coefficients used in the Ricci tensor calculations.
  • A participant expresses gratitude for the clarification, acknowledging the oversight in their calculations.
Participants do not reach a consensus on the initial calculations, but there is agreement on the importance of excluding certain terms in the Riemann tensor when calculating the Ricci tensor. The discussion reflects a mix of confusion and clarification regarding the mathematical details.
Participants note that the calculations involve subtleties related to the indices of the Riemann tensor and the Ricci tensor, which may not be immediately apparent, especially when using computational tools like Maple.
wildemar
This is driving me nuts.
(I originally posted this to the coursework section, but in thinking about this, I felt that it might not be the right place (this is for a term paper, not really any ongoing coursework, so there). Hope I'm not imposing ... I feel quite embarrassed on this one, since it should be simple. Enough of my babbling.)
Mission statement
The problem deals with an extension to the Robertson-Walker Metric for a flat space. To the usual 3 spatial dimensions with scale factor a(t), d more are appended with another scale factor b(t).
I thus have the following line-element:
[itex] \mathrm{d}s^2 = - \mathrm{d}t^2 + a(t)^2 \sum_{\alpha=1}^{3} (\mathrm{d} x^\alpha)^2+ b(t)^2 \sum_{\mu=1}^{3} (\mathrm{d} x^\mu)^2[/itex]
I need to calculate the Ricci-Tensor for this.
My attempt at a solution
For the given metric, I get the following Riemann (we can assume that this is right, Maple says so, but feel free to correct me (the paper I'm using as a reference has positive signs for the first two components listed):
[itex] R_{0 \alpha 0 \alpha} = -a \ddot{a} \quad\quad<br /> R_{0 \mu 0 \mu} = -b \ddot{b} \quad\quad<br /> R_{\alpha\beta\alpha\beta} = a^2 \dot{a}^2 \quad\quad<br /> R_{\mu\nu\mu\nu} = b^2 \dot{b}^2 \quad\quad<br /> R_{\alpha\mu\alpha\mu} = a \dot{a} b \dot{b}[/itex]
(Note that alpha and beta run over the usual 3 spatial dimensions while mu and nu run over the d additional ones. All Latin indices run over all dimensions available, including time.)
I then said (no summation convention here)
[tex] \begin{align*}<br /> R_{ab}<br /> &= \sum_{c,d=0}^{4+d} g^{cd} R_{cadb}<br /> = \sum_{c=0}^{4+d} g^{cc} R_{cacb} \\<br /> &= (-1) \cdot R_{0a0b}<br /> + \sum_{\alpha = 1}^{3} a^{-2} R_{\alpha a \alpha b}<br /> + \sum_{\mu = 4}^{3+d} b^{-2} R_{\mu a \mu b} \\<br /> &= (-1) \cdot R_{0 a 0 b}<br /> + \quad 3 \, \frac{R_{\alpha a \alpha b}}{a^2} \quad\<br /> + \quad d \, \frac{R_{\mu a \mu b}}{b^2}<br /> \end{align*}[/tex]
where the Greek indices in the last line are symbolic in the way that you can use any value that is in line with the above convention as all those components are equal.
So with this I get
[tex] \begin{align*}<br /> R_{00} &= -3\frac{\ddot{a}}{a} - d \frac{\ddot{b}}{b} \\<br /> R_{\alpha\alpha} &= a \ddot{a} + 3 \dot{a}^2 + d \frac{a \dot{a} \dot{b}}{b} \\<br /> R_{\mu\mu} &= b \ddot{b} + 3 \frac{\dot{a} b \dot{b}}{a} + d \dot{b}^2<br /> \end{align*}[/tex]
The Problem
Both Maple and the paper I'm working through say that in the second line it should read 2 instead of 3 and in the third d-1 instead of d (I apparently can't use any additional latex in this post, so you'll have to use your imaginations).
That is, in the last two lines, the "pure" spatial terms (those that have no mixed indices of normal and higher dimensions) occur on time less than what I calculate.
I can't for the life of me find the error I'm making. This isn't a complicated calculation at all, but I'm completely stumped.
Uhm, anyone?
If what I'm writing is unclear, or even if you think what I do is correct, I'd really like to know. Sorry to bother you.
Maybe this is more appropriate in the GR section? If so, can I move the thread?
wildemar said:
Uhm, anyone?
I just saw your post. I have been doing tons of calculations similar to these for calculations in brane world models (and I do everything by hand) so I will check your question tomorrow (it's too late now, I need to go to sleep)
Regards
wildemar said:
Uhm, anyone?
Hi,
I only had time to look at your calculation this afternoon, sorry about the delay.
The reason is this: The components of the Riemann tensor are zero whenever the four indices are identical. So [tex]R_{1111} = R_{2222} = R_{3333} ... = 0[/tex]
Therefore you have to be careful. When you give the expressions for [tex]R_{\alpha \beta \alpha \beta}[/tex] for example, it is valid only if [tex]\alpha \neq \beta[/tex].
Now, look at when you calculate the Ricci tensor with two spatial indices. In that case, you cannot write
[tex]\sum_{\alpha=1}^3 a^{-2} R_{\alpha a \alpha b} = 3 \frac{R_{\alpha a \alpha b}}{a^2}[/tex]
It's clear if you write it out. For example consider [tex]R_{11}[/tex]
We should get
[tex]R_{11} = \frac{1}{a^2} \bigl( R_{2121} + R_{3131} \bigr) = 2 \dot{a}^2[/tex]
i.e., the term [tex]R_{1111}[/tex] must not be included.
The same problem arises when you find R with two [tex]\mu[/tex] indices. In that case, the sum over the mu that you wrote should not include the term [tex]R_{\mu \mu \mu \mu}[/tex] so the factor in front of the sum is (d-1), not d.
I hope this helps. It is tricky. And since most people just use Maple, they don't have to worry about this kind of subtleties. Since I have done tons of calculations by hand, I have had to deal with this kind of tricky issues very often and had nobody to help. I hope that my hours of struggle will have helped you out a bit!
Patrick
*slaps forehead*
Man! Thanks Patrick. That was it, of course. Gee, there it was, right before my eyes and I didn't see. You're the man now, dog! :)
Really, I can not express how grateful I am. Now I can finally start doing some serious calculations again.
regards,
/W
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 30 ·
  • · Replies 38 ·
