Hollow sphere gravity question
  • Context: Undergrad
  • Thread starter Thread starter GENIERE
    Gravity Sphere
The discussion revolves around the gravitational behavior of a small mass located inside a hollow sphere of large mass, exploring concepts from both Newtonian mechanics and General Relativity (GR). Participants examine whether the small object would be accelerated toward the inner surface of the sphere and the implications of symmetry and rotation.
  • Some participants assert that in Newtonian mechanics, a small mass inside a hollow sphere experiences no net gravitational force, thus would not be accelerated toward the inner surface.
  • Others reference Feynman's lectures, suggesting that the same result holds true in GR, although some express uncertainty about this application.
  • One participant notes that if the small mass starts at the center, symmetry dictates it remains there, but questions arise about the behavior if the mass is not centered.
  • Another participant introduces the idea of a rotating shell, speculating that this could affect the gravitational dynamics in GR, though they acknowledge the complexity of the scenario.
  • Several participants discuss the concept of gravitational forces canceling out at any point inside a perfect sphere, emphasizing that the gravitational pulls from all sides are equal.
  • A hypothetical scenario involving a marble in a spherical hole at the Earth's center is presented as a thought experiment to illustrate the gravitational effects discussed.
  • One participant reiterates that gravitational force is a vector quantity, leading to the conclusion that a mass at the center experiences no gravity due to equal forces acting in all directions.
  • Another participant emphasizes that the gravitational field is zero everywhere within a uniform spherical shell, not just at the center.
Participants generally agree that a small mass inside a hollow sphere does not experience a net gravitational force, but there are competing views regarding the implications of rotation and the application of GR. The discussion remains unresolved regarding the effects of rotation and the specifics of GR in this context.
Some participants express uncertainty about the application of GR compared to Newtonian mechanics, and there are unresolved questions about the effects of rotation on gravitational behavior within the hollow sphere.
GENIERE
I seem to have managed to confuse myself again. If I assume the only matter in the universe was an object of very small mass and size located inside a hollow sphere of very large mass, would the small object be accelerated toward the inner surface?
Thanks
Not in Newtonian mechanics. I seem to remember that Feynman derives this result in his lectures.
I can't remember whether or not it is true in GR. Although I recall using this result (that it is not accelerated to the inner side of the sphere) in cosmology so I suspect it is true in GR too.
Can anyone verify me here?
Matt
If you started exactly at the center, then symmetry will require that you stay there - independent of Newtonian or GR based approach. I also believe this may be true if you are not at the center, but am not sure if GR predicts otherwise.
How about if you were not at the center, and the shell was rotating? In Newtonian gravity the rotation would not matter, but in GR it probably would do something. (I'll gloss over the issue of whether it makes sense to talk of a rotating shell when essentially all the matter of the universe is located in that shell!)
Well, according to gravity and geometry, no. any position inside the hollow sphere would have the same gravitational pulls form all sides, so gravity would not cause any changes. Think about a circle on a graph. say point A is at the center. the circle around it is equal in all directions. now point a moves up the y-axis say 1/2 the radius. now it is closer to the upper limit, right? but, as it gets closer to that upper limit, more circle line has gotten below it. since gravity depends on distance and mass, it will always be the case that inside a perfect sphere at any point gravitational forces will cancel out.
I'm 90% sure.
If one could excavate a spherical hole, say, 10-foot diameter at the exact mass center of the earth, and a marble was held then released in the center of the hole, what would happen?
The answer to this question is the answer to your question
Thanks
Seems to me that if the sphere of matter were at the centre of the surrounding shell it would stay there. This is because the gravitational attractiveness of the sphere of matter would be concentrated at the centre. Whichever way a hypothetical person looked or measured the gravitational attraction of the shell from this point, they would find it to be equal.
The matter would be in equilibrium with the surrounding shell and would not, could not move, unless something changed and upset the balance.
You have the right analysis but the wrong conclusion. Gravitational force is a vector quantity; it has direction as well as amount. So somebody at the center of the sphere looks in any direction there's an amount of gravity directed toward him from that direction. And in the opposite direction there's an equal amount pointed that way. So the two of them cancel each other out. And that works for any direction, so all the gravity cancels out. Thus the person at the center of the hollow sphere experiences no gravity at all.
Furthermore with a little geometry you can see that this happens not only at the center but at any point inside the sphere.
From the viewpoint of ordinary Newtonian gravity, the field is zero everywhere within a uniform spherical shell. Not just at the center.
The gravitational field outside the spherical shell is equivalent to an equal mass concentrated at its center.
Thanks folks!
  • · Replies 28 ·
  • · Replies 69 ·
