How long does it take for a white dwarf to go supernova through accretion?
  • Context: Graduate
  • Thread starter Thread starter Sanjay87
    Accretion White dwarf
The discussion revolves around the time it takes for a white dwarf to go supernova through the process of accretion from a companion star. Participants explore the theoretical estimates and relevant literature on accretion rates and the mechanisms involved in type Ia supernovae.
  • San inquires about the typical time frame for a white dwarf to go supernova through accretion, suggesting a range of thousands to millions of years.
  • One participant references Townsley and Bildsten (2003), noting that accretion rates for cataclysmic variables range from 10^(-11) to 10^(-8) solar masses per year, and provides a rough estimate that reaching the Chandrasekhar limit could take approximately 3.8 x 10^7 to 3.8 x 10^10 years, depending on initial mass and accretion rate.
  • Another participant expresses interest in the accretion rate for neutron stars in binary systems, indicating a curiosity about comparative rates.
  • A further response offers a theoretical framework for calculating accretion rates based on disk luminosity and the Eddington limit, suggesting that this could provide insights into maximum accretion rates.
Participants do not reach a consensus on the specific time frame for a white dwarf to go supernova, and various estimates and models are presented without resolution of the differences.
The discussion highlights the uncertainty surrounding the mechanisms of type Ia supernovae and the dependence on various assumptions regarding accretion rates and initial conditions.
Sanjay87
Hi,
Let's say we have a white dwarf accreting material from a giant partner. How long would it typically take for the white dwarf to go supernova? Is it of the order of a thousand years? A million? Any references would be much appreciated.
Thanks,
San
Astronomy news on Phys.org
Townsley and Bildsten (2003) (http://xxx.lanl.gov/abs/astro-ph/0309208) find accretion rates for cataclysmic variables 10^(-11) - 10^(-8) Msun/yr, but I am sure you can find more papers on this (I just did a very short search), and different values depending on the assumptions.
A very rough estimate: the Chandrasekhar limit of 1.38 solar masses could be reached in approximately 3.8 10^7 - 3.8 10^10 years, assuming that you start with a white dwarf of 1 solar mass and accrete at the above rate.
There is a lot of work going on on this subject and the mechanism of type Ia supernovae is still not well understood. I think you would find the existing literature very interesting.
Out of general interest, do you have any idea what the accretion rate is for a neutron star in a binary system?
I don't have a number to give you on neutron stars, but here is a simple way to calculate an accretion rate:
A rough theoretical estimate for the accretion rate on a disk is given by the luminosity of the disk:
L{disk} = G M M{dot} / 2R
where L{disk} the disk luminosity, M{dot} the mass accretion rate and M and R the mass and radius of the accreting object (you find a derivation in 'An Introduction to Modern Astrophysics' by Carroll and Ostlie).
The maximum luminosity an object can have and still stay in hydrostatic equilibrium is given by the Eddington limit:
L{max} / L_sun = 3.8 10^4 (M/M_sun)
Substituting the Eddington limit in the first equation can give you an estimate of the highest possible accretion rate.
I hope this helped! People more relevant to the field could post answers based on current research.
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 19 ·
