Multi-dimensional root finding
  • Thread starter Thread starter natski
    Root
The discussion revolves around methods for multi-dimensional root finding for non-linear functions of the form f(x,y,z), g(x,y,z), and h(x,y,z). Participants explore numerical and computational approaches to determine the values of x, y, and z based on measured values of these functions.
  • One participant suggests that the problem can be framed as finding the intersection of surfaces defined by the functions, proposing a matrix approach to solve for the variables.
  • Another participant points out that Cramer's rule is only applicable to linear equations and mentions the potential use of Broyden's method, which does not require the Jacobian.
  • A different approach is proposed involving a specific form of the function and a transformation to simplify the equations, potentially leading to a new formulation that could be solved using matrices.
  • Concerns are raised about the necessity of calculating the Jacobian in Broyden's method, with suggestions that the transformation could allow for the use of matrices and Cramer's rule to find the variables.
Participants express differing views on the applicability of matrix methods, the use of Cramer's rule, and the necessity of the Jacobian in the context of Broyden's method. The discussion remains unresolved with multiple competing approaches and no consensus on the best method.
Limitations include the complexity of the functions and the potential need for assumptions regarding their forms. The discussion also highlights the challenges in applying certain mathematical methods to non-linear equations.
natski
Hi all,
Consider that one has several functions, say 3, of the form f(x,y,z) and g(x,y,z) and h(x,y,z). You know the form of these equations and they are non-linear, long, messy equations. f', g' and h' are even longer and messier and therefore assume that they cannot be found.
Now consider you measure f, g and h and want to determine x, y and z.
What method is recommended for solving this in a numerical and computationally efficient (but simple to implement) manner?
Cheers,
Natski
Well, its if 3 dimensions (x,y,z), and you can find the values of the functions, what you'll essentially be left with are equations of surfaces. Any solution you obtain will be the intersection of those surfaces. If you know the functions, I'm pretty sure you could use matrices to solve for them.
For example, you have three functions of the form
[tex]f(x,y,z)=a_{0}+a_{1}x+...+a_{n}x^n+b_0+b_1y+...+b_ny^n +c_0+c_1z+...+c_nz^n[/tex]
along with all the xy, yz, zx terms of degree n, then you could create a matrix equation such that AX=B where A holds the coefficients, X holds the values x, x^2, etc and B holds the values of the 3 functions.
then X=A-1B will give you a solution.
Cramer's rule only applies for linear equations.
A matrix method would not be involve the Jacobian which cannot be computed in this case.
I think the solution lies within Broyden's method.
Thats pretty messy though, perhaps another way to do so would be to assume that the function you have is of the form,
[tex]f(x,y,z)=(ax+by)^n + (cy+dz)^n +(ez+fx)^n[/tex]
Since you know f, you could find out the values of the constants. Perhaps to simplify the above equation, you could apply the transformation
[tex]X=\frac{a}{\sqrt{a^2+b^2}}x+\frac{b}{\sqrt{a^2+b^2}}y[/tex]
[tex]Y=\frac{c}{\sqrt{c^2+d^2}}y+\frac{d}{\sqrt{a^2+d^2}}z[/tex]
[tex]Z=\frac{e}{\sqrt{e^2+f^2}}z+\frac{f}{\sqrt{e^2+f^2}}x[/tex]
That would transform the above equation into
[tex]f(X,Y,Z)=k_1X^n +k_2Y^n+k_3Z^n[/tex]
where
[tex]k_1=(a^2+b^2)^{\frac{n}{2}}[/tex]
[tex]k_2=(c^2+d^2)^{\frac{n}{2}}[/tex]
[tex]k_3=(e^2+f^2)^{\frac{n}{2}}[/tex]
I don't know much about Broyden's method, but from what wikipedia says, wouldn't you have to calculate the Jacobian there too?
If you use the transformation, I think you could use matrices to solve the equations and you can find the jacobian of the transformation. Then you could use cramer's rule to solve for Xn, Yn, Zn.
  • · Replies 26 ·
