Virial Theorem and Frictional Forces
The discussion revolves around the virial theorem and the behavior of velocity-dependent frictional forces within its framework. Participants explore the conditions under which these forces may be considered negligible, particularly focusing on the implications of time averaging and the boundedness of the particle's trajectory.
  • One participant questions why velocity-dependent frictional forces disappear in the context of the virial theorem, noting a lack of explanation in existing literature.
  • Another participant suggests that for forces proportional to velocity, the virial is related to the time average of the dot product of velocity and position, which can be zero under certain conditions.
  • A participant elaborates on the concept of boundedness, explaining that if the particle's position remains within a finite distance from the origin, the time average of the total derivative of the squared position approaches zero.
  • The same participant defines time averaging and provides a mathematical expression to illustrate how the bounded nature of the position leads to a zero average for the derivative of the squared position.
Participants express varying levels of understanding regarding the implications of boundedness and time averaging, but there is no consensus on the broader applicability of these concepts to all cases involving velocity-dependent frictional forces.
The discussion includes assumptions about the nature of the forces involved and the conditions under which the virial theorem applies, particularly regarding the boundedness of the particle's trajectory and the time averaging process. These aspects remain unresolved and are subject to further exploration.
Old Guy
In the virial theorem, why do velocity-dependent frictional forces disappear? I've seen this stated a number of times, but never any explanation. (And, obviously, haven't been able to figure it out myself!)
I don't know if it is true in general, but for forces which are directly proportional to the velocity the virial is
proportional to
[tex] \langle{\vec v}\cdot{\vec r}\rangle\;,[/tex]
where [itex]\langle\ldots\rangle[/itex] is time averaging.
But, that virial is the time average of a total derivative w.r.t time (i.e., of r^2/2) and so is zero if the quantity r is bounded and the averaging is done over a long time. (Or if the motion is periodic and the averaging is done over a period of the motion).
Thanks very much; can you expand a bit on your answer? Specifically, what does it mean for r to be "bounded", and how does it make the time average of a total time derivative go to zero? I understand about the "long time" bit, although even there it would seem to approach a limit of zero, and not actually equalling zero. Am I thinking about this right? Thanks again.
I'll expand and expound:
First of all, I'm discussing a single classical particle.
The particle travels along a trajectory
[tex] {\vec r}(t)[/tex]
under the influence of some forces.
When I say that r is bounded I mean that I can choose a "bound"--some (possibly large) number (R) such that I always have
[tex] r(t)<R\;,[/tex]
for all t. Put more simply, the particle never escapes off to infinity and is always within some finite (though perhaps large) distance from the origin. Also, Because r is bounded so too is r^2 bounded.
Next, I define the "time averaging" as
[tex] \langle\ldots\rangle\equiv<br /> \lim_{T\to\infty}\frac{1}{T}\int_0^Tdt(\ldots)[/tex]
So then
[tex] \langle \frac{d r^2}{dt}\rangle<br /> =\lim_{T\to\infty}\frac{1}{T}\int_0^T\frac{d r^2}{dt}<br /> =\lim_{T\to\infty}\frac{r^2(T)-r^2(0)}{T}\;.[/tex]
But that last quantity is necessarily less than
[tex] lim_{T\to\infty}<br /> \frac{R^2}{T}=0\;.[/tex]
(it's also necessarily greater than -R^2/T)
Thus, because the quantity r^2 was bounded the time-average of the derivative of r^2 was zero. This is true for any bounded quantity.
  • · Replies 77 ·
  • · Replies 35 ·
