What Magnetic Field Keeps an Electron Moving Horizontally?
The problem involves a 10keV electron moving horizontally through a region with a downward electric field of 100V/cm. Participants are tasked with determining the magnitude and direction of the magnetic field required for the electron to maintain horizontal motion, while also considering the trajectory if the electric field is turned off.
  • Participants discuss the relationship between electric and magnetic fields, questioning the relevance and origin of the equation presented. There are attempts to relate the forces acting on the electron to its motion and to explore the conditions for maintaining constant motion.
The discussion is ongoing, with participants exploring different interpretations of the forces involved. Some guidance has been offered regarding the need for force balance, but there is no explicit consensus on the approach to take or the specific relationships between the fields.
Participants are navigating through the implications of the Lorentz force and the conditions necessary for the electron's trajectory, while also grappling with the definitions and roles of the electric and magnetic fields in this context.
nick227
A 10keV electron moving horizontally enters a region of space in which there is directed downward an electric field of magnitude 100V/cm. (a) what are the magnitude and direction of the smallest magnetic field that will allow the electron to continue to move horizontally? Ignore the gravitational force. (b) If the electric field is produced by a capacitor whose plates are 2.50m apart, describe the trajectory of the electron if the electric field is turned off when the electron enters the field (i.e. just the magnetic field is left on.)
E/B = V/Bd
if I'm trying to find B,i can find the voltage by converting the 10keV and E is given also, but what is d?
I don't recognise that equation immediately... and maybe I'm just tired at ten to three in the morning but it looks to me like B should cancel from both sides, rendering it useless! What does it mean, and where does it come from?
If I were you, I'd want the expression for the force exerted on a charged, moving particle by electric and magnetic fields. What's that?
are you thinking of the lorentz law? f=qE+qv X B? though, coulomb's law also comes into mind.
i was looking through my book and found this equation:
e/me = V(theta)/(B2ld)
this was in the chapter where the question came from, in the section where the question came from...
but how does this relate to the electric field?
I've no idea! Yes, I was thinking of the lorentz force. If it was a classical mechanics problem, and you had an equation which gave you all of the forces acting on the object, what would you do if you wanted the object to carry on its constant motion in a straight line?
wouldn't the magnetic be the same as the electric field, just opposite in direction. because if you want the electron to have no deflection, the B-field and E-field have to be the same in different direction (i think). so using that theory (its probably wrong), the magnetic field is 100 and it is the direction is directed upwards.
You're on the right lines, but not quite. You need the forces to balance (How would you represent this in an equation?) but it doesn't quite follow that the fields are opposite, because the force exerted by a magnetic field doesn't act in the direction of the field (Just to confuse you :-p)
  • · Replies 0 ·
