Thread Closed
Hydrogen to Helium
Share Thread Thread Tools
Sep26-08, 07:50 PM   #1
Question
Hydrogen to Helium
I am a freshman and in physical science but we have not yet come to fusion or anything like that. One day I jsut started to think.. what if you took an ordinary hydrogen atom (not an isotope.) and added 1 proton, 1 electron, and 2 neutrons in whatever way you could. Would you get helium, or just a very strange hydrogen atom, or what?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Sep26-08, 08:03 PM   #2
Recognitions:
Homework Helper Homework Help
Yes you get helium, it's quite easy to do in large quantities if you have the correct equipement ( a star)
Sep26-08, 08:11 PM   #3
Quote by mgb_phys View Post
Thats kind of cool.. would you happen to know how? and if so would you care to try to explain it to me?
Sep26-08, 08:34 PM   #4
Admin
Hydrogen to Helium
Quote by Softballokie View Post
The isotopes of hydrogen are protium (the atom is comprised of one electron orbiting a single proton), deuterium (one electron orbiting a nucleus composed of one proton and one neutron), and tritium (one electron orbiting a nucleus composed of one proton and two neutrons). In all three isotopes, the single proton provides the positive charge which is equal in magnitude but opposite of the electron.
The helium nucleus contains two protons. He-3 has a nucleus containing 2p+n, while the very common, He-4 had a nucleus (2p, 2n).
Adding p + p + 2n into one nucleus will give (2p,2n) = α, which is the nucleus of He-4.
Stars use the proton-proton cycle with interim steps to produce He-4, and there is a second cycle (CNO) in which protons are fused into the nuclei, the last one of which experiences a (p,α) reaction.
http://csep10.phys.utk.edu/astr162/l...y/ppchain.html
http://csep10.phys.utk.edu/astr162/lect/energy/cno.html
http://hyperphysics.phy-astr.gsu.edu...ro/procyc.html
Sep26-08, 09:50 PM   #5
Protons by themselves aren't going to stick together, the system of two protons and no neutrons is not stable (don't ask me why).
You can add a neutron to each proton and make two deuterium atoms. Those are stable. You should be able simply to expose a hydrogen tank to neutron radiation to produce deuterium. I'm not sure how big the cross section is. In practice it's much easier to electrolyze ordinary water and separate deuterium from protium. There's always a measurable amount of deuterium in the water.
If you then take a quantity of deuterium and heat it to a very high temperature, deuterium nuclei will start smashing into each other and occasionally fuse together into helium. They are positively charged and electrostatic force will work to keep them apart. You need high temperature (i.e. high velocities of individual molecules) to bring them together close enough for d+d -> He reaction to go through. You don't start seeing significant conversion rates till you heat plasma to millions of degrees.
Then you cool the resulting mix (plasma consists of ionized nuclei and free electrons), electrons will naturally form orbits and create atoms.
Sep26-08, 10:39 PM   #6
Recognitions:
The details depend on the exact temperature and pressure of your particular star. The important point is that all electorns, protons, nuetrons are the same and all heavier atoms are built up from hydrogen by similair processes in stars.
(ok - except some He3 that was formed in the big bang)
Thread Closed
Tags
fusion, helium, hydrogen
Thread Tools
Similar Threads for: Hydrogen to Helium
Thread Forum Replies
Hydrogen on one side, Helium on the other, and nothing in between ? Quantum Physics 11
Hydrogen to Helium Introductory Physics Homework 14
Hydrogen to Helium...Helium to heavier elements Chemistry 3
