| Thread Closed |
Parallel Plate Capacitor (work and potential difference) |
Share Thread | Thread Tools |
| Sep26-08, 07:53 PM | #1 |
Professor Milly Coulomb finds it takes 3.0 J of work to drag, at constant speed, a -9.0 mC charge between the plates of a parallel plate capacitor. (a) What is the work done by the electrical force in taking the charge between the plates? (b) What is the potential difference between the plates of the capacitor? 2. Relevant equations PE = (QV) / 2 V = 2PE / Q 3. The attempt at a solution b) V = 2PE / Q V = (2 * 3) / -.009 V = -666.667 V For part b, I tried both positive and negative values but they were both wrong. For part a, I tried the values of 0 and 3 but they were wrong also. Thanks for anyone who helps!
| Sep26-08, 10:50 PM | #2 |
Recognitions:
a) You have to be more explicit as to what you tried here. Positive and negative values of what?
b) Why did you multiply it by 2? |
| Sep27-08, 12:40 AM | #3 |
a) +/- 666.67 as answers for the problem when changing the charge. They were both incorect.
b) I based it off the formula PE = .5QV |
| Sep27-08, 04:44 AM | #4 |
Recognitions:
a) Work is done to move charge across a potential difference. This work is done against the field. So what is the work done by the field?
b) The formula 1/2QV gives you the amount of energy stored in the capacitor, with Q being the amount of charge on the capacitor plates, not as you have interpreted it, the amount of charge the person has moved from one plate to the other. So for this, you have to think back to what constitutes the work done in moving the charge across the plates. In particular, think of what is the work done in moving a charge across a potential difference V? |
| Sep27-08, 02:36 PM | #5 |
I figured out part a, but part b is confusing given the problem. I found a formula in my textbook about potential difference between the two capacitor plates as: V = Ed. However this cannot be found as E and d are not given in the problem. I also know that V = Q/C, but capacitance is unknown as well.
| Sep27-08, 10:35 PM | #6 |
Recognitions:
So, in this case, you can't rely on that formula to do it. As I said earlier, think in terms of the formula you have for work done to move a charge q over a potential difference V. This definition is more fundamental than the concept of capacitance. You don't need to understand capacitance to come up with that.
| Sep28-08, 10:06 AM | #7 |
Okay, I finally got it now. Thanks a lot!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Parallel Plate Capacitor (work and potential difference)
| Non-parallel Plate Capacitor | Introductory Physics Homework | 2 | ||
| Work Done on a Parallel Plate Capacitor | Introductory Physics Homework | 1 | ||
| A proton is released from rest at the positive plate of a parallel-plate capacitor. | Introductory Physics Homework | 16 | ||
| An analytic solution for the potential due to a circular parallel plate capacitor | Classical Physics | 0 | ||
