Is the Woodward Effect the key to propellant-less propulsion?
  • Context: Graduate
  • Thread starter Thread starter sanman
    Explain
The discussion centers on the Woodward Effect, also known as the Mach Effect, proposed by a University of California physicist. This concept suggests that a mass moving at relativistic speeds within another mass can alter its effective weight based on its velocity. By oscillating the surrounding mass and timing the inner mass's movements with these oscillations, a net change in momentum can be achieved, potentially enabling propellant-less propulsion. The conversation raises questions about the conservation of momentum and the interaction of relativistic masses with space.
  • Understanding of relativistic physics
  • Familiarity with the concept of momentum conservation
  • Knowledge of oscillatory motion in physics
  • Basic principles of mass-energy equivalence
  • Research the Woodward Effect and its implications for propulsion systems
  • Explore relativistic mass changes and their effects on momentum
  • Study oscillatory motion and its applications in physics
  • Investigate the relationship between mass, energy, and space in relativistic contexts
Physicists, aerospace engineers, and researchers interested in advanced propulsion technologies and the theoretical implications of relativistic motion.
sanman
Okay, here's a different idea for "propellant-less" propulsion:
http://adsabs.harvard.edu/abs/2004AIPC..699.1138M
It's based on some idea by a University of California physicist named Woodward, who himself preferred to use the term "Mach Effect"
Basically, his idea was that if you have mass moving at relativistic velocity inside another mass, then the internal moving mass can make itself heavier or lighter depending on how fast it's moving.
So then if you make the overall system oscillate (surrounding mass), and you time the movements of the inner mass with the oscillations, then you can selectively impart more momentum in one part of the oscillation than in another, for the overall system. This would create a net change in momentum for the system.
Did anybody catch what I said there?
Hmm, this one has me scratching my head.So where did the extra mass/momentum on demand come from? Well, it came from the relativistic motion of the inner mass. You can switch that motion on or off, depending on which way your overall mass-system is oscillating. If momentum is to be conserved, then where did the difference in momentum go? It went to, umm, space? It went to whatever it is that retards the motion of a relativistically-moving mass. The universe?
Hmm, tell me, if I lift up a cyclotron that's whirling particles around at extremely high speed, will it feel heavier to me than if I lifted it up while it was turned off?
Does anybody see what I'm saying here?
In that sense, is a relativistically-moving mass really a closed system? Or is it somehow interacting with space itself, where space itself can't really be described as closed?
Pardon me, while I re-post this in the Relativity forum, where it might be more appropriate.
  • · Replies 19 ·
18K
  • · Replies 17 ·
  • · Replies 96 ·
13K
  • · Replies 30 ·
