Magnitude of en electric field and electrostatic field
The discussion revolves around determining the electric field and electrostatic potential of a uniformly charged, finite-thickness spherical shell with inner radius a and outer radius b. Participants are exploring the application of Gauss's law to find the electric field in various regions, including inside and outside the shell.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of Gauss's law and its applicability to the problem's spherical symmetry. Questions arise regarding the expression for the electric field due to surface charge and the calculation of enclosed charge within the spherical shell.
The conversation is ongoing, with participants sharing their understanding of Gauss's law and its implications for the problem. Some have attempted to derive equations based on their notes, while others are clarifying concepts and questioning assumptions about the charge distribution and Gaussian surfaces.
Participants note the challenge of applying Gauss's law and the need for clarity on the charge enclosed by different Gaussian surfaces, particularly when the radius is less than the inner radius of the shell.
katrascythe
I have a solid, insulating, finite-thickness spherical shell (inner radius a, outer radius b). It's uniformly charged with a total charge of Q. I'm looking for the electric field E, "everywhere in space, including points outside and inside the spherical shell"
Also, I'm looking for the electrostatic potential of the inner and outer surface of the shell
E = (1/4pie0)(Q/r^2)r
I'm pretty much lost on this problem.
[tex]\vec{E}(\vec{r})=\frac{1}{4 \pi {\epsilon}_0} \frac{q}{r^2} \hat{r}[/tex]
is the electric field due to a point charge at the origin.
What is the expression for the electric field due to a surface charge [tex]\sigma[/tex]?
Have you learned Gauss's law yet?
Yes, we've learned Gauss' law but I'm unsure how to apply it to the problem.
Due to the surface charge sigma wouldn't the equation be (2*pi*(radius)^2*sigma)/epsilon?
No, the correct formula for calculating the electric field due to a surface charge [itex]\sigma (\vec{r'})[/itex] is:
[tex]\vec{E}(\vec{r})=\frac{1}{4 \pi {\epsilon}_0} \int_{\mathcal{S}} \frac{\sigma (\vec{r'})}{|\vec{r}-\vec{r'}|^2} \widehat{\vec{r}-\vec{r'}} da'[/tex]
Where [itex]|\vec{r}-\vec{r'}|[/itex] is the distance between an infinitesimal piece, dq, of the surface charge located at [itex]\vec{r'}[/itex] and the field point [itex]\vec{r}[/itex]. And [itex]\hat{\vec{r}-\vec{r'}}[/itex] is the unit vector pointing from the infinitesimal source dq, to the field point.
Such integrals are usually very difficult to evaluate, so I recommend using Gauss's Law if you can...what types of symmetry can Gauss's law be used for? What type of symmetry is present in the given problem?
Gauss' law can be used for cylindrical, spherical, and planar symmetry. So here there is spherical symmetry. Looking this up gives me the equation of
E = (QA)/(4*pi*epsilon_o*r^2)
Okay, but what is Q_enclosed inside the spherical shell? How about outside? (I'm assuming you meant Q_enclosed by Q_a)
Did you just look up this answer or did you calculate yourself using Gauss's law?
Hi gabbagabbahey ! :smile:
In the middle of text, the PF server doesn't like a lot of ordinary LaTeX, so use itex and /itex instead of tex and /tex (for "inline LaTeX"): :wink:
Where [itex]|\vec{r}-\vec{r'}|[/itex] is the distance between an infinitesimal piece, dq, of the surface charge located at [itex]\vec{r'}[/itex] and the field point [itex]\vec{r}[/itex]. And [itex]\widehat{\vec{r}-\vec{r'}}[/itex] is the unit vector pointing from the infinitesimal source dq, to the field point.
I was able to get the equation through a few equations we have in our notes. Gauss' Law is phi = Q/epsilon_0. The magnitude within each sphere would be constant, so phi is the integral of E*ds. That gives 4*pi*r^2*E.
Setting the equations equal to each other is 4*pi*r^2*E = Q/epsilon_0
Solving for E is how I got the equation.
I meant the QA as the Q enclosed by the inner shell, sorry. And the outer shell would be QB.
Thanks for the tip tiny tim:smile:
Well, Gauss's law in integral form is:
[tex]\Phi= \oint_{\mathcal{GS}} \vec{E} \cdot \vec{da} =\frac{Q_{enclosed}}{{\epsilon}_0}[/tex]
Where [itex]\mathcal{GS}[/itex] is your Gaussian surface and [itex]Q_{enclosed}[/itex] is the charge enclosed by your Gaussian surface.
so, what are you using for your [itex]\mathcal{GS}[/itex]? how much charge does it enclose when its radius [itex]r[/itex] is less than [itex]a[/itex]?
  • · Replies 17 ·
  • · Replies 22 ·
