Thread Closed
Circuit/Resistors Problem
Share Thread Thread Tools
Sep28-08, 08:33 PM   #1
Four resistors are connected to a battery as shown in the figure. The current in the battery is I, the battery emf is E, and the resistor values are R1 = R, R2 = 2R, R3 = 4R, and R4 = 3R.
-Determine the potential difference across each resistor in terms of E.
-Determine the current in each resistor in terms of I.
-In the limit that R3 → infinity, what are the new values of the current in each resistor in terms of I, the original current in the battery?
2. Relevant equations
V=IR
Rtotal=R1+R2+... (Series)
1/2Rtotal=1/R1 + 1/R2 ... (Parallel)
3. The attempt at a solution
I've tried a bunch of different combos, and i'm just wondering if there is some sort of way to do this.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Sep28-08, 09:32 PM   #2
hmm still trying. anyone out there?
Sep28-08, 09:39 PM   #3
R2 and R3 are in series...we'll call their combination Rs. R4 is parallel to Rs...we'll call their combination Rp. R1 is in series with Rp...we'll call their combination Rt. Once you find Rt, the circuit should simply be a battery in series with a resistance of Rt. From this, you could find I1, the current running through the battery and R1. I1 splits into I2 and I3 at a junction. Note that the voltage between the junctions is the same per path.
Sep28-08, 10:03 PM   #4
Recognitions:
Homework Helper Homework Help
Quote by hobo skinoski View Post
V=IR
As Gear300 suggests you should first find the equivalent resistance of the entire network because that will yield the current from the E source. Then it is simply a matter of splitting the current between the legs as you go through the network.
The equivalent resistance R1234 is found by finding
R23 = R2 + R3
Then
R234 = R4 || R23
Then
R1234 = R1 + R234
Then I = E/R1234
Thread Closed
Thread Tools
Similar Threads for: Circuit/Resistors Problem
Thread Forum Replies
Finding current in a complex circuit with resistors Advanced Physics Homework 4
circuit with resistors in series and two power supplies Introductory Physics Homework 12
Finding the currents of four resistors in a circuit. Introductory Physics Homework 15
Resistors in a 555 Timer Circuit Engineering, Comp Sci, & Technology Homework 1
Simplyfing Parallel/Series Resistors in a Circuit Engineering, Comp Sci, & Technology Homework 4
