Register to reply
Understanding horizontal and vertical components of a falling object
by science_rules
Tags: velocity components
Share this thread:
science_rules
#1
Sep29-08, 09:23 PM
P: 78
I want to understand this: In the case of a dropped object, the horizontal component of the velocity with which the object hits the ground is not the same thing as the horizontal velocity itself, am i right? The horizontal component of the velocity when the object hits the ground means the horizontal component of the initial velocity?
Say an object is dropped from a plane at a certain speed(horizontal velocity), air resistance is negligable. The horizontal component of the velocity with which the object hits the ground would be zero because air resistance is negligable?
Phys.Org News Partner Physics news on Phys.org
Mapping the optimal route between two quantum states
Spin-based electronics: New material successfully tested
Verifying the future of quantum computing
jdlinke
#2
Sep29-08, 10:57 PM
P: 14
Assuming air resistance is negligible, the horizontal component of initial velocity and of final velocity are equal, but they are not equal to zero (unless the object has been dropped straight downward along the y-axis, in which case there is no horizontal component). So when the object hits the ground, the magnitude of its velocity in the horizontal direction is exactly the same as the magnitude of its velocity in the horizontal direction at the moment is was released/launched.
The horizontal ACCELERATION is zero, though, because no force is acting upon the object in the horizontal direction.
Keep in mind that in the sort of situation you're talking about, the horizontal component is completely separate from the vertical component. One has nothing to do with th other, unless you're combining them to look at the complete trajectory of the object.
Register to reply
Related Discussions
Vertical vs Horizontal takeoff (VTO vs HTO) Mechanical Engineering 4
Crane Problem: Find Horizontal and Vertical Components Introductory Physics Homework 4
(101)Horizontal/Vertical forces on an object by a turntable Introductory Physics Homework 4
Vertical/Horizontal Asymptotes Precalculus Mathematics Homework 2
Horizontal/vertical polarization Quantum Physics 1
