Time for boat to make two sets of displacements
  • Thread starter Thread starter Maiia
    Boat Sets Time
The problem involves a boat moving through a river with a given speed relative to the water and the speed of the river's current. The task is to determine the time taken for the boat to complete a round trip consisting of two displacements: one downstream and one upstream.
  • The original poster attempts to use the Pythagorean theorem to find the resultant velocity and applies the formula for distance to calculate time for each leg of the trip. Some participants question the velocity values used for downstream and upstream travel, suggesting a need for clarification on how the boat's speed interacts with the river's current.
Participants are exploring different interpretations of the boat's speed relative to the water and the current. Some guidance is offered regarding the use of relative velocity concepts, but no consensus has been reached on the correct approach to the problem.
There is a mention of potential confusion regarding the use of the boat's speed and the river's current, indicating that assumptions about these values may need to be revisited.
Maiia
I would really appreciate if someone could check my work for this poblem b.c i seem to be getting the wrong answer.
Problem: A boat moves through a river at 6.1 m/s relative to the water, regardless of the boat's direction. If the water in the river is flowing at 2.4 m/s, how long does it take the boat to make a round trip consisting of a 246 m displacement downstream followed by a 194 m displacement upstream? Answer in units of seconds.
First, I used the pythagorean theorem to find the resultant vector- 6.555150647m/s. Then, used distance=Velocity * time . I plugged in 246m for distance and 2.4m/s for the velocity to get 102.5 sec for time. I did the same thing with the second displacement to get 183.3333333s for time. Then I added them together for a total time of 183.3333333s.
If its going down stream then up stream surly that means its going from A to B and then B to A.
If its moving 6.1m/s relative to the water down stream it would be moving at 8.5m/s
up stream it would be moving at 3.7m/s (unless it is taking 6.1m/s as its actual velocity, but then why would you have the speed of the water?).
hmm i kinda follow, but how do you find the time?
With distance = velocity * time. If your having trouble with the boat moving relative to the water think of trying to measure the speed of a car from inside another moving car. If you were measuring car A (30mph) from car B (20mph) it would look like car A is going 10mph.
