Why Are Differential Equations Considered Difficult?
The discussion centers around the perceived difficulty of differential equations, exploring reasons why they are considered challenging compared to other areas of mathematics. Participants share their thoughts on the nature of differential equations, the skills required to solve them, and the variability in individual experiences with abstract mathematical concepts.
  • Homework-related
  • One participant expresses a lack of knowledge about differential equations and seeks to understand why they are deemed difficult.
  • Another participant suggests that difficulty varies among individuals, particularly in relation to abstract problem-solving abilities, with calculus being a notable dividing line.
  • A participant defines a differential equation and provides examples, indicating that the difficulty of solving them can depend on the specific equation presented.
  • It is noted that while algebraic equations can often be solved mechanically, differential equations require knowledge of various methods and conditions, with some being unsolvable analytically.
  • One participant emphasizes the importance of knowing the solution type before attempting to solve a differential equation, contrasting it with algebraic equations that yield simple variable solutions.
  • Another participant introduces the concept of an integrating factor as a useful tool in solving differential equations, highlighting its significance in calculus.
  • Links to external resources for examples and explanations of differential equations are shared by participants.
Participants express a range of views on the difficulty of differential equations, with no consensus on a singular reason for their complexity. The discussion reflects differing experiences and insights regarding the skills needed to tackle these equations.
Some participants mention prerequisites such as mastery of algebra and calculus, indicating that understanding differential equations may depend on prior knowledge and skills. There are also references to specific methods and conditions that affect the solvability of differential equations, which remain unresolved in the discussion.
Rockazella
To start off I know nothing about them. My question is why are they considerd so difficult?
I'm in a precalc class and would like to study some higher level math on my own time. I have heard that these equations are very difficult to solve or understand or something, just wondering what makes this so?
People differ greatly
in their ability to solve abstract problems. Most don't have much trouble with Algebra or Geometry, but for some reason Calculus seems to separate those with abstract abilites from those who don't.
a differential equation is an equation with some kind of derivative in it. for instance dy/dx + y = 1. This is saying the function plus the first derivative of that same function is always equal to 1. There would be a family of y's that you could plug into this equation and that would be called the solution of the differential equation. Sometimes finding a solution can be difficult be sometimes its really really easy. For this equation it would be very easy, but for sin(x) * dy/dx + y = 1 it would be more difficult. So difficutly just depends on the particular equation.
For the most part normal algebraic equations can be solved nearly mechanically, follow the rules, crank the handle of the machine and out pots a solution.
Such is not the case for differential equations, there are methods to use if certian conditions are met, and there are some which simply cannot be solved analytically.
The difficuty comes in learning when to apply which methods.
The key to solving most differential equations is knowing the solution befor you start. When you solve an algebraic equation the solution is a simple variable, the solution to a DE is a function, for many types of DE we can recognize the general function which solves the equation.
For example a DE of the form
X(t)"+ λX(t) = 0
has a general solution
of X(t)= ACos(λt)+ Bsin(λt) OR
X(t) = Aeλt+ Be-λt
Where A and B are constants.
A and B cannot be determined with the information I have provided, the complete statement of a DE includes either boundary condions, that is the value of the solution at some point (usually an end point) or an initial value (if the independent varialbe is time) which specifies the value at some time.
I really cannot present a course in DE, but perhaps you can see parts of the quest that lie ahead of you.
To really get an understanding of DE you need to understand functions, you must have a mastery of algebra and a good understanding of calculus, both differential and integral.
Good luck.
another "making it easy" factor
Hello string,
When it comes to diff eqn there is a cool tool called an integrating factor: e^[f'(x)]which is as important to calculus as L'Hospital's (that's how Google spells it)Rule is to topology or Avagadro's Number is to Chemistry. Properly used the factor works magically on EQs that appear to be insoluable.
The most important rule in EQ that a beginner needs to respect is "separation of variables: E.g., dy/dx = yx^2 multiply thru by "ydx" gives ydy =[x^2]dx Both sides are now integratable and are equal [excepting some arbitrary integrating constant]. Cheers Jim
This prooves to be a useful site:
http://www.physics.ohio-state.edu/~physedu/mapletutorial/tutorials/diff_eqs/intro.html
  • · Replies 25 ·
  • · Replies 19 ·
