| Thread Closed |
flow problem with a two diemsional water flow divider |
Share Thread | Thread Tools |
| Oct1-08, 10:16 AM | #1 |
Question Details:
A two-dimensional water flow divider is shown in the sketch. The flow in through opening A varies linearly from 3 to 6 m/s and is inclined with angle α=45 degrees to the opening itself. The area of the A opening is .4m2 per unit depth, that of B is .2m2 per unit depth, and that of C is .15 m2 per unit depth. the flow at B, normal to the opening, varies linearly from 3 to 5 m/s; and the flow at C, normal to the opening is approximately uniform. Find velocity at C. I'm having difficult setting up the relation needed to solve the problem. I've attached a figure for the problem. I would appriciate a step by step solution. This is what I was thinking: Min=Mb out +Mc out. what expression would I use for Min and Mb out I'm thinking Mc out would equal V*.45m2*cos(0) would Mb out= integral from 0 to 4 of (x/2)+3 dx and Min= integral from 0 to7 of (3x/7)+3dx than just sove for V correct? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: flow problem with a two diemsional water flow divider
| Linear Algebra, Water Flow Problem | Calculus & Beyond Homework | 3 | ||
| Tap water flow and water diameter at end of it (Bernoulli eqzn...) | Introductory Physics Homework | 4 | ||
| Rate of flow - height of water problem | Differential Equations | 4 | ||
| water flow venturi meter problem! Heeeelp please :) | Introductory Physics Homework | 21 | ||
| HELP! relationship between rate of flow of water and height of water column | Introductory Physics Homework | 1 | ||
