Electric motors & faraday's law
The discussion centers on the application of Faraday's Law in the context of a wire coil connected to a power supply and a multimeter. Eliza's setup demonstrates that only the bare part of the wire coil will conduct current, while the insulated section will not. The orientation of the coil relative to the magnetic field determines which end acts as the north or south pole. When the coil is placed above a magnet and the switch is closed, the interaction between the magnetic field and the current will dictate the coil's behavior.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Knowledge of magnetic flux and its calculation
  • Familiarity with basic electrical components: power supply, switch, multimeter
  • Concept of magnetic poles and their orientation
  • Study the application of Faraday's Law in electric motors
  • Learn about the principles of magnetic flux and its role in electromagnetism
  • Explore the behavior of coils in magnetic fields using simulations
  • Investigate the effects of coil orientation on induced electromotive force (EMF)
Students studying electromagnetism, electrical engineers, and educators looking to explain the principles of electric motors and electromagnetic induction.
jackd
Eliza connects a power supply, switch, and a multimeter (in ammeter mode) in series with a wire coil. The wire coil is held into place by 2 connecting wire leads. One of the wire leads has been stripped off of the insulating enamel coating so that half the wire is bare; the other lead has been completely stripped bare.
1. What orientations of the coil will give a current through it due to the battery?
2. During the time that there is a current through the coil, which side of the coil will act like a north pole and which side will act like a south pole? Explain?
3. How will the coil behave when placed above the magnet and the switch is closed?
Faraday's Law: E=-d(magnetic flux)/dt
Magnetic Flux = B*Acos([tex]\theta[/tex]
The part without coating will give a current, but the part that has coating will not?
Very lost...
Yes.
For the rest, it's hard to see what's going on without a figure.
