Thread Closed
Direction of movement for particles in a wave
Share Thread Thread Tools
Oct2-08, 09:34 PM   #1
The question includes a graph of a wave (on a string) with several points labeled on the graph. We are asked to determine the direction of the transverse velocity of each point on the wave as well as the transverse acceleration.
2. Relevant equations
3. The attempt at a solution
I know that the direction of transverse acceleration depends on the curvature of the wave, i.e. for negative curvature the transverse acceleration is also negative. However I'm not sure how to figure out which direction the velocity is moving in. I guessed that the points whose y-coordinates were larger than 0 had negative transverse velocity because that is the direction of equilibrium, and similarly points below the x-axis had positive transverse velocity. But this assumes the equilibrium position of the string is at x = 0, how do you tell for general case? Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Thread Closed
Thread Tools
Similar Threads for: Direction of movement for particles in a wave
Thread Forum Replies
What kind of wave is associated with particles , in wave particle duality? Quantum Physics 7
Movement of Charged Particles in a field Introductory Physics Homework 3
Do massless particles always have momentum in the direction of travel? Quantum Physics 12
A small question, do all + charged particles have the same spin direction? Classical Physics 2
2 particles 1 direction Introductory Physics Homework 4
