Where Should a Rectangular Plate Be Suspended for Equal Oscillation Periods?
The discussion revolves around a physics problem involving the oscillation of a uniform rectangular plate suspended at different points. Participants are exploring how to determine the position along the line connecting the suspension point and the center of mass that results in equal oscillation periods.
  • Participants are attempting to derive the position of a second suspension point that yields the same oscillation period as the original point. They are discussing the moment of inertia and the equations governing the period of oscillation, questioning the algebraic steps involved.
There is an ongoing exploration of different approaches to the problem, with participants sharing their equations and results. Some participants express confusion over the algebra, while others suggest alternative formulations and check each other's reasoning without reaching a definitive conclusion.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is a reference to a textbook answer that some participants are trying to reconcile with their own calculations.
discoverer02
I think I'm lost in the ugly algebra, but I want to make sure.
A uniform rectangular plate is suspended at point P (top center of the rectangle), and swings in the plane of the paper about an axis through P. At what other point between P and O (center of the rectangle), along PO, could the plate be suspended to have the same period of oscillation as it has around P. O is the cm of the plate.
The rectangle has a width and b length.
The answer is (a^2b)/(3(a^2 + b^2))
T = period.
I = moment of inertia
M = mass
1) T = 2pi(I/mgd)^(1/2) I = (1/12)M(a^2 + b^2) + M(b/2)^2
d = b/2
2) T = 2pi[(8b^2 + 2a^2)/(12mgb)]^(1/2)
I then substitute (b/2 - x) for d in equation 1 and set it equal to equation 2 and solve for x, but I'm not getting the correct answer. Is this the correct approach?
Thanks.
The perpetually confused discoverer02.
I think you're on the right track, but it's not quite that "easy".
The point you're looking for (let's call it Q) has a different moment of inertia, so the expression for the period when oscillating about Q will be different.
Then, if x is the distance from cm to Q, I think the equation to solve is:
IP/(b/2) = IQ/x
but I haven't been able to get that answer. You're right, the algebra is uuuuugly[/size].
Where'd you get that answer?
I get
x = (a2+b2)/6b, where x is the distance from the center of mass to the new point Q.
(Assuming my equation IP/(b/2) = IQ/x is correct.)
The answer came from my trusty textbook.
I did remember to substitute the new distance from cm to pivot point into the moment of inertia, but try as I may I don't come up with the same terms the book does.
I was basically trying to solve the same equation except I was using b/2-x instead of x which makes the problem even uglier. You're solving for the distance from the pivot and I'm solving for the distance from the center of mass, but all in all both equations seem OK to me. I've posted my question on our class's bulletin board also. I'll let you know if there's a problem with the answer in the book.
Thanks for your help.
You're welcome.
My answer seems to check out. If x = (a2+b2)/6b, then
IQ = Icm + m((a2+b2)/6b)2
IQ = (m/12)(a2+b2) + (m/36b2)(a2+b2)2
and if you divide that mess by (a2+b2)/6b you get a worse mess that eventually simplifies to
(ma2 + 4mb2)/6b
And similarly
IP = Icm + (mb2)/4
IP = (m/12)(a2+b2) + (mb2)/4
and if you divide that by 2b, it also becomes
(ma2 + 4mb2)/6b
So I think that proves that x = (a2+b2)/6b
  • · Replies 37 ·
  • · Replies 26 ·
