| Thread Closed |
Pushing Crate up Frictionless Slope.. Find Work |
Share Thread | Thread Tools |
| Oct5-08, 01:52 PM | #1 |
A man pushes a create which weighs 75 N upward along a frictionless slope that makes an angle of 30° with the horizontal. The force he exerts is parallel to the slope. If the speed of the crate increases at a rate of 0.5m/s^2, then the work done by the man while moving the crate a distance of 1.5m is: -62J, +62J, -41J, +41J, none of the above 2. Relevant equations W = Fdcos(theta) W(done by gravity)= mgdcos(theta) 3. The attempt at a solution I'm not sure exactly how to approach this problem as they supply an increasing acceleration of 0.5m/s^2. Otherwise I would just apply W = Fdcos(theta). I also know that gravity has an effect on this, but I'm not sure how to include it in this situation |
| Oct5-08, 02:01 PM | #2 |
Draw a free body diagram and resolve the weight of the box into components.
Weight pointing down the plane = mg sin theta Weight normal to the plane (the normal force) = mg cos theta. If the object is accelerating upward at .5m/s^2, what does that tell you about the net force on the object? |
| Oct5-08, 04:09 PM | #3 |
Well the 75N is due to gravity, so the mass is 7.653kg
Breaking it into horizontal and vertical components: mgsin(theta) = 7.653x9.8xsin(30) = 37.5 mgcos(theta) = 7.653x9.8xcos(30) = 64.951 If the object is accelerating upward at 0.5 m/s^2 and the mass is 7.653kg, then the force is 3.826N |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Pushing Crate up Frictionless Slope.. Find Work
| Work pushing a mass up a plank | Introductory Physics Homework | 2 | ||
| [SOLVED] Please help: A box on a frictionless plane, find the power based on work and | Introductory Physics Homework | 0 | ||
| [SOLVED] Mininum Work to Pull Crate | Introductory Physics Homework | 9 | ||
| Work Required to Push/Pull a Crate | Introductory Physics Homework | 8 | ||
| Pulley Problem, 1 crate hanging, 1 crate on an incline | Introductory Physics Homework | 1 | ||
