Commuting creation and annihilation operators
The forum discussion focuses on calculating the commutator of powers of creation and annihilation operators, specifically the expression [a^m, (a^{\dagger})^n]. The user successfully derived the relation [a^m, a^{\dagger}] = m a^{m-1} [a, a^{\dagger}] but struggles with applying this to the more complex commutator. Another participant clarifies that the commutator can be simplified to [a^m, (a^{\dagger})^n] = n m a^{m-1} (a^{\dagger})^{n-1} [a, a^{\dagger}], emphasizing that the commutator results in a c-number. The discussion highlights the importance of recognizing the nature of operators and c-numbers in quantum mechanics.
  • Understanding of quantum mechanics, specifically creation and annihilation operators.
  • Familiarity with commutation relations in quantum mechanics.
  • Knowledge of operator algebra and manipulation.
  • Basic proficiency in mathematical notation used in physics.
  • Study the derivation of commutation relations for creation and annihilation operators.
  • Learn about the implications of c-numbers in quantum mechanics.
  • Explore recursive methods for calculating commutators in operator algebra.
  • Investigate the role of operator ordering in quantum mechanics.
Physicists, quantum mechanics students, and researchers working with quantum field theory or operator algebra will benefit from this discussion.
Rettaw
Hello, I have the missfortune of having to calculate a commutator with some powers of the creation and the annihilation operators, something like:
[tex]\left[ a^m , (a^{\dagger})^n \right][/tex]
I have managed to derive
[tex]\left[ a^m , (a^{\dagger})^n \right]= m a^{m-1} \left[ a , a^{\dagger} \right][/tex]
(altought I should really have remebered that) but I don't know how to use that to calculate
the big thing other than by recursive application of it, and that's very messy.
Any suggestions?
[tex]\left[ a^m , a^{\dagger} \right]= m a^{m-1} \left[ a , a^{\dagger} \right] \quad\cdots (*)[/tex]
Any suggestions?
(I guess you got a typo in your second equation. I corrected it in the way I thought.)
Actually, by directly repeating use of the eq(*), you will get
[tex]\left[ a^m , (a^{\dagger})^n \right] = nma^{m-1}(a^\dagger)^{n-1}\left[a,a^\dagger\right][/tex].
What you only have to notice is, the commutator is a c-number.
Application of eq(*) to [tex]\left[ a^m , (a^{\dagger})^n \right][/tex] is just of as many lines calculation as the derivation of eq(*).
Actually, the answer can be read off directly, but I think you should go into the calculation, and should not feel cumbersome please.
Cheers
Yeah, you're right it's supposed to be only [tex]a^{\dagger}[/tex] and no powers of n.
Still, I'm not entirely convinced, the [tex]\left[ a , a^{\dagger} \right][/tex] is indeed a c-number, but the [tex]\left[ a^m , a^{\dagger} \right][/tex] is an operator, and when I expand the full [tex]\left[ a^m , (a^{\dagger})^n \right][/tex] I get things that contain higher powes of the operators and thus I'm quite sure do not commute trivially.
So are you claiming that if I fully expand the commutator until I only have [tex]\left[ a , a^{\dagger} \right][/tex] I get all the operators that I've pulled outside in the correct order to be able to write your final result?
  • · Replies 0 ·
  • · Replies 24 ·
