Why are heat pipes not used in PEM fuel cells?
The discussion centers on the absence of heat pipes or passive cooling systems in larger PEM (Proton Exchange Membrane) fuel cells, particularly in comparison to their use in methanol fuel cells. Participants explore potential reasons for this phenomenon, including power density considerations and the exploration of technology.
  • One participant questions why heat pipes are not utilized in larger PEM fuel cells, suggesting that it may relate to the higher power density of these fuel cells compared to others.
  • Another participant inquires about the presence of embedded water/air cooling plates between fuel cells, indicating a curiosity about existing cooling methods.
  • A participant hypothesizes that the excess heat produced at high current densities in PEM fuel cells may be used to evaporate water at the cathode to prevent back diffusion, while also noting the need to maintain electrolyte membrane hydration.
  • It is mentioned that cooling systems are generally used in fuel cells, typically involving channels in bipolar plates, but heat pipes operate differently as passive devices relying on phase change of a working fluid.
  • A participant notes the existence of patents and some research on heat pipes in PEM fuel cells and methanol fuel cells, but finds a lack of information regarding their application in larger hydrogen PEM fuel cells.
Participants express curiosity and propose various hypotheses regarding the use of heat pipes in PEM fuel cells, but no consensus is reached on the reasons for their absence or the effectiveness of alternative cooling methods.
Limitations include potential assumptions about the operational conditions of PEM fuel cells, the specific design choices made in fuel cell technology, and the varying definitions of cooling methods across different fuel cell types.
Topher925
Just curious as to why you don't find heat pipes or any passive cooling in larger PEM type fuel cells. I have seen them used in methanol fuel cells but not FCs for hydrogen. Is there a good reason for this? Is it because the power density of fuel cells is typically higher than that in many others or is because the technology just hasn't really been explored? Any input would be greatly appreciated as I really need a solid answer for this question.
Anyone?
I am curious to know the answer to this.
Are you sure there are no embedded water/air cooling plates between each fuel cell?
I can only take a stab at this problem by saying if the PEM fuel cell is operating at high current densities, it is going to produce a lot of water. Perhaps the excess heat is being used to evaporate the H20 at the cathode to prevent back diffusion. But then again, they have to keep the electrolyte membrane hydrated so they have to remove the heat or they're putting in more water as its input.
Cooling systems are used in almost all fuel cells. For medium to large cells this usually consists of channels integrated into the bipolar plates of each FC in the FC stack. Water or some heat carrying fluid is then pumped through those channels in order to regulate heat and temperature. Heat pipes however do not operate on this principle. Heat pipes are passive devices that work by phase change of a the working fluid sealed in the heat tube. Not only are heat pipes passive but they have an extremely high heat flux compared to other methods of thermal management. I've found a lot of patents for heat pipes in PEMFCs and a couple papers for methanol fuel cells but nothing for larger hydrogen PEMFCs.
  • · Replies 26 ·
  • · Replies 39 ·
