Analysis of an= n1/2: Cauchy Criterion Examined
  • Thread starter Thread starter Kudaros
    Analysis Cauchy
The discussion focuses on the sequence defined by an = n^(1/2) and its properties concerning the Cauchy criterion. It is established that while |an+1 - an| approaches 0 as n approaches infinity, the sequence an does not satisfy the Cauchy criterion. Participants clarify that to demonstrate this, one must consider two indices, m and n, where m is significantly larger than n, rather than simply using m = n + 1. The limit evaluation involves multiplying by (sqrt(n+1) + sqrt(n)) to simplify the expression.
  • Understanding of sequences and limits in calculus.
  • Familiarity with the Cauchy criterion for sequences.
  • Knowledge of algebraic manipulation of square roots.
  • Concept of contractive sequences in analysis.
  • Study the properties of Cauchy sequences in depth.
  • Learn techniques for evaluating limits involving square roots.
  • Explore contractive sequences and their implications in analysis.
  • Practice problems related to sequences and convergence criteria.
Students of calculus, mathematicians interested in sequence analysis, and educators teaching concepts of convergence and limits.
Kudaros
Define the Sequence an= n1/2 where n is a natural number.
Show that |an+1-an| -> 0 but an is not a cauchy sequence
(Ignore this paragraph)Well, unfortunately I am stuck on the very first part. How exactly do I evaluate the limit as n -> infinity of |(n+1)^(1/2) - n^(1/2)| ? any hint at a trick would be most welcome (unless of course I am not seeing something that is obvious).
As for the rest, I need to show an is not a Cauchy sequence. The definition of a Cauchy sequence uses two sequences with different subscripts, m and n. In this case, can I take n+1 to be m and keep n as itself?
I think I need to show that the distance between the two sequences, an+1 and an is not decreasing as n becomes large.
edit: found limit.
Also, re-reading the question I see a flaw in my above statement. I just need to show that for any given m and n, as I vary them independently, they do not meet the cauchy criterion. The problem itself states that looking only at the n+1 term appears to meet the criterion, but in fact does not.
Confirm or deny?
To evaluate the limit multiply by (sqrt(n+1)+sqrt(n))/(sqrt(n+1)+sqrt(n)) and simplify. And to show it's not Cauchy, no, don't take m=n+1. You're going to show that goes to zero. Take m MUCH bigger than n. Say 4 times n?
Thanks, now I understand that definition/concept. Incidentally, I also understand the contractive sequence concept now.
  • · Replies 28 ·
