Charge.E field and Faraday's cage
  • Context: Graduate
  • Thread starter Thread starter fisico30
    Cage Field
The discussion revolves around the behavior of electric fields in relation to a static charge and an accelerating charge placed inside a metallic box, specifically focusing on the implications of Faraday's cage and Gauss's law. Participants explore theoretical aspects, potential misconceptions, and the effects of different conductor shapes on electric fields.
  • Some participants assert that a static charge inside a metallic box creates an electric field inside the box, with zero field in the layer between the inner and outer walls, and an external field as if the box were absent.
  • Others argue that for an accelerating charge, the electric field produced will be zero outside the box, raising questions about the application of Gauss's law in this scenario.
  • One participant suggests that the external electric field behaves as though all charge is concentrated at the center of a conducting sphere, regardless of the charge's position inside the cavity.
  • Another participant questions whether this behavior holds true for non-spherical boxes, suggesting that charge distribution may differ based on the shape of the conductor.
  • There is a discussion about the implications of a time-varying electric field generated by an accelerating charge and how it relates to static fields outside the conductor.
  • Some participants highlight that if the conductor is not perfect, a time-varying field would exist outside the sphere, contrasting with the behavior of a perfect conductor.
  • Questions arise regarding the effects of an AC current source inside a perfect metal box and whether the electric flux through a Gaussian surface surrounding the box would be zero.
Participants express differing views on the behavior of electric fields in relation to static and accelerating charges, with no consensus reached on several key points, particularly regarding the implications of conductor shape and the nature of the fields produced.
Participants note that the discussion is limited by assumptions about the perfection of conductors and the specific configurations of charges, which may affect the applicability of Gauss's law and the resulting electric fields.
fisico30
Hello everyone.
If a static charge is placed inside a metallic box, there is going to be an E field inside the box, zero in the layer between the inner and outer walls of the box, and a field E outside the box, as if the box was not there.
If the same charge inside the metal box is accelerated instead, the E field that it produces will be zero outside the volume of the box (assume a perfectly conducting walls perfect reflection).
Why?
What about Gauss law? How does it apply in the second case for a Gaussian surface that surrounds the box?
thanks
There are two mistakes. For simplicity, let's consider the box to be a conducting sphere.
1. For a static configuration, there will be some complicated field inside the sphere, zero field between the inner and outer layers of the sphere, and then outside the sphere, the electric field will be as though all the charge were concentrated at the center. This last bit is important.
2. For the accelerating charge, assuming the sphere's inner surface is perfectly reflective, you will still have a static field outside the sphere, as though all the charge were concentrated at the center. Note that the external field does not change, and so therefore does not radiate any energy; thus energy is conserved and Gauss's Law is also satisfied.
WOW. never knew that. is this always true regardless of the shape of the box?
ok, I can see that for a sphere shaped box. the charges on the outer surface are free to go where ever they want so they spread out evenly. for a square box though the charges should want to go to the corners.
See Thorne's note at the bottom of the page:
http://www.feynmanlectures.info/flp_errata.html
The field outside depends on the shape of the conductor and does not depend on the position of the charge inside the cavity. The field outside is that of a point charge
ONLY if the conductor is a sphere.
Great answer!
so, even before I read Thorne's notes, an accelerating charge creates inside the box a time-varying EM field, but outside the box a static field?
How is that possible?
thanks
because the field can't penetrate the conductor.
thanks granpa,
I can see that, but which charge creates a "static" field outside the metal box?
There is only a surface current at the inner surface of the conductor.
Sure, perfect reflection at the inside wall. No field inside the conductor, but outside of it , I cannot get why there is a "static" field as Niehoff says.
A static field requires static charge.
if charge q is inside the sphere then charge -q will be on the inner surface of the conductor. the conductor is neutral so there must be a charge q floating around in the conductor somewhere. since its free to go wherever it wants it goes to the outside surface and spreads out evenly.
Hi again granpa,
I continue to agree with you so far. On the outer surface there is that positive q. But it should be a time-changing charge and create a time-varying field outside, and not a static one...
what would cause it to vary? the field of the inner charge ends at the inner surface.
true granpa,
but the inner charge "should" be related to the outer charge in the conductor, since they both derive from an induction process.
The inner surface has a time changing surface current, which implies a time changing surface charge density (continuity equation).
Therefore I would think that the outer charge density would continue to redistribute itself (therefore moving, accelerating) and causing a time chaging E field outside the box...
you're thinking to hard. its not that complicated. the field of the inner change and all its effects ends at the inner surface. end of story.
got it! thanks for persevering.
Note that if the conductor were NOT perfect (i.e., if it had a finite [itex]\epsilon[/itex]), then you WOULD have a time-varying field outside the sphere. The trick is that you're using a perfect conductor.
thanks Mr. Niehoff.
If an AC current source (instead of an accelerating charge) was inside the perfect metal box, then waves (E field ) would be generated inside the box, no field in the conductor, and no field outside the conductor or still a static field, right?
The net charge of the current source is zero.
If we used a Gaussian surface to surround the metal box, the E flux would be zero or not zero ?
Gauss's Law is never violated.
I believe so too.
If we surrounds a radiating antenna with a Gaussian surface, the flux has to be nonzero.
The net charge on the metal antenna is however zero...
Calculate it. Or consider, for example, the direction of the E field, and the direction in which power is transported.
Gauss's law is really never violated.
11K
