Vector proofs for triangles and some vector plane questions
The discussion revolves around vector proofs related to triangles, including the concurrency of altitudes and angle bisectors, as well as distance calculations involving points and planes. The subject area encompasses vector geometry and spatial reasoning.
  • Mixed
  • Participants explore various vector approaches to demonstrate that the altitudes and angle bisectors of a triangle intersect at a common point. Some participants question their reasoning and seek confirmation of their methods, while others provide hints or partial setups for the problems.
Several participants have shared their attempts at solving the problems, with some providing detailed calculations and others asking for validation of their approaches. There is an ongoing exchange of ideas, with no clear consensus yet on the correctness of the methods presented.
Participants are working under the constraints of homework guidelines, which may limit the extent of assistance they can provide to one another. Some assumptions about the properties of vectors and geometric relationships are being examined, but no definitive resolutions have been reached.
rock.freak667
1) Show by the use of vectors that the three altitudes of a triangle pass through the same point.
2) Show using vectos that the bisectors of the angles of a triangle pass through thr same point.
3)Find the distance from the point (1,0,-2) to the plane 3x-2y+z+1=0
4) Find the distance between the lines r=(-1,-2,0)+t(1,0,-1) and r=(1,0,1)+t(1,-1,2)
5) Find the cosine of the angle between the two planes x-2y+3z-4=0 and 2x+y-z-5=0
For the first two I just need some hints on how to prove them.
3) The equation of the plane is 3x-2y+z+1=0, meaning that the normal vector,N, to the plane is (3,-2,1). [itex]|N|=\sqrt{14}[/itex].
So the unit vector in the direction of the normal vector:
[tex]n= \frac{3i-2j+k}{\sqrt{14}}[/tex]
Let P=(1,0,-2).
I need to choose any point on the given plane.
Let Q=(1,2,0)
The distance I need is [itex]PQcos\theta[/itex]=|PQ.n|
So the vector PQ=Q-P=(1,2,0)-(1,0,-2)=(0,2,2)
therefore |PQ.n|=[(0,2,2).(3,-2,1)]/sqrt(14)
[tex]=\frac{2}{\sqrt{14}}[/tex]
5) The normal vector,n1 for the plane x-2y+3z-4=0 is (1,-2,3).
The normal vector,n2 for the plane 2x+y-z-5=0 is (2,1,-1)
Thus [itex]n_1.n_2= (1,-2,3).(2,1,-1)=-3[/itex]
[itex]|n_1|=\sqrt{14}]/itex]<br /> [itex]|n_2|=\sqrt{6}[/itex]<br /> <br /> thus <br /> <br /> [tex]cos \theta = \frac{-3}{\sqrt{14} \sqrt{6}}[/tex][/itex]
4)Direction of first line,u1=(1,0,-1)
2nd line,u2=(1,-1,2)
[tex]\vec{OA}=(1,-2,0)[/tex]
[tex]\vec{OB}=(1,0,1)[/tex]
[tex]\vec{AB}=(0,2,1)[/tex]
[tex]u_1 \times u_2=-i-3j-k \Rightarrow |u_1 \times u_2|=\sqrt{11}[/tex]
Thus the required distance is
[tex]|\frac{(-1,-3,-1).(0,2,1)}{\sqrt{14}}|=\frac{7}{\sqrt{11}}[/tex]
6) Find the equation of a plane such that any point on this plane is equidistant from points (1,1,1) and (3,1,5).
Solution:
Midpt. AB i.e. a point on the req'd plane= ( (1+3)/2, (1+1)/2, (1+5)/2 )=(2,1,3)
The normal vector is the vector AB=-(1,1,1)+(3,1,5)=(2,0,4). Thus (1,0,2) is also a normal vector.
Using the definition that (r-a).n=0
(x-2,y-1,z-3).(1,0,2)=0
=> x-2+2z-6=0
so x+2z=8.
Correct?
Can someone tell me if I am going correct for the 2nd one?
I created a vector triangle, ABC such that a+b+c=0
Drew the bisectors,AP;BR;CQ such that AP=b/2 ; BR=c/2 and CQ=a/2.
Finding the equation of the line passing through [itex]\vec{AP}[/itex]
[tex]l_1: r=a+ t(a+ \frac{b}{2})[/tex]
the line through [itex]\vec{BR}[/itex]
[tex]l_2: r= c+ u(c+ \frac{a}{2})[/tex]
Of they meet,then
[tex]a+ t(a+ \frac{b}{2})= c+ u(c+ \frac{a}{2})[/tex]
If they are equal, then a=c.
and a(1+t)=c(1+u) as well. i.e. t=u. So they intersect. Good so far?
Here is what I tried for the 1st question. I drew a triangle ABC, with H as the point of intersection of the three altitudes.
AH.BC=0
(AO+OH).(BO+OC)=0
(OA.OB-OB.OH-OA.OC+OC.OH)=0 ...1
BH.AC=0
(BO+OH).(AO+OC)=0
(OA.OB-OA.OH-OC.OB+OC.OH)=0...2
eq'n 2-1 gives
-OB.OH-OA.OC-OA.OH-OC.OB=0
-OB.(OH-OC)+OA.(OH-OC)=0
-OB.CH+OA.CH=0
CH.(OA-OB)=0
CH.BA=0
Meaning that CH is perpendicular to AB. Thus all three altitudes intersect at the same point,H.
Correct??
