How Does a Grenade's Shockwave Cause Fatal Injuries?
  • Thread starter astonmartin
In summary, a shock wave from a blast can cause massive damage to the human body due to its high speed and force. Grenades are more deadly when detonated in water because the water absorbs the kinetic energy of the blast, making it less dangerous to those standing nearby. However, grenades primarily cause harm through their shrapnel, which is why they are designed with metal pieces. Stun grenades or "flash bang" grenades are less lethal because they produce a large blast but minimal shrapnel.
astonmartin
23
In other words, how does a "blast" actually end up killing someone? I realize that if shrapnel or something goes through you, you'll probably die, but how does the shockwave itself do damage?
Also, I've heard that grenades are more deadly if they explode in the water than in the air; anybody know why?
A shock wave ("blast") has mechanical force. If this wave of compressed air hits a human body while traveling at high speed, it can do massive damage in much the same way as a vehicle moving at high speed. Of course, the shock wave is made of compressed air which has a lot more give and a lot less mass than your average car. So, it's rather like being hit by a very light car with pillows or bubble wrap on the front end. But, it's also moving a lot faster than most cars.
A blast that detonates underwater can be more deadly than a blast in air, but only to people who are in that water. The person who is in the water near an explosive device when it goes off will be hit by a blast wave made of compressed water rather than compressed air. However, an explosive that detonates in water is less dangerous to people standing nearby, but out of the water. The person standing close enough to be killed by a bomb if it were sitting on the ground could survive the same blast if the bomb were placed in a bucket of water. The water absorbs much of the kinetic energy of the blast.
I should also point out that grenades kill and injure people with their shrapnel, almost exclusively. This is why the explosive core of the grenade is wrapped in bits of metal that are cut into small squares or rectangles. If you are standing next to a grenade when it goes off, and by some extraordinary stroke of luck all the bits of shrapnel happened to miss you, you will probably survive with only some eardrum damage. Stun grenades, or "flash bang" grenades, operate on this principle. They produce a large blast but almost no shrapnel. The noise and brightness of the flash are very disorienting, and the shock wave can actually knock a person down, but the chances of being killed by one, even at close proximity, are very slim.
Likes Greg Bernhardt
Grenades are designed to be lethal weapons and can cause significant damage to individuals and their surroundings. The primary cause of death from a grenade explosion is the blast itself, which can result in severe injuries and fatalities.
When a grenade detonates, it releases a high-pressure shockwave that travels outward at a high speed. This shockwave can cause damage to the body's internal organs, especially the lungs and brain. The sudden increase in pressure can also rupture blood vessels, leading to severe bleeding and potential death.
In addition to the shockwave, grenades also produce shrapnel, which is small fragments of metal or other materials that are propelled outwards by the explosion. These shrapnel pieces can penetrate the body and cause severe injuries, leading to death.
Regarding your question about grenades being more deadly in water than in the air, this is due to the difference in density between air and water. Water is denser than air, so the shockwave from a grenade explosion is more concentrated and can travel further in water, causing more damage. Additionally, the water can also amplify the effects of the shrapnel, making it more lethal.
In conclusion, grenades can kill people through the blast and shrapnel they produce, and the shockwave can cause severe injuries to internal organs. The density of the medium in which the grenade explodes can also affect its lethality.
1. How does a grenade explode?
A grenade explodes due to a chemical reaction inside the device. The fuse on the grenade ignites a small explosive charge, which then sets off the main explosive compound inside the grenade. This creates a powerful blast that can cause damage and injury.
2. How far can a grenade kill someone?
The lethal radius of a grenade varies depending on the type of grenade and the surrounding environment. However, on average, a grenade can cause fatal injuries within a radius of 15-20 meters.
3. What makes grenades lethal?
Grenades are designed to release a large amount of energy in a short period of time, creating a powerful explosion. This explosion can cause severe damage to the body, including internal injuries, severe burns, and shrapnel wounds, all of which can be fatal.
4. Can a grenade kill someone without exploding?
Yes, a grenade can still cause fatal injuries even if it does not explode. The sheer force of the grenade being thrown and the impact it makes upon landing can cause severe trauma to the body, resulting in death.
5. What types of injuries can a grenade cause?
A grenade explosion can cause a variety of injuries, including blunt force trauma, shrapnel wounds, burns, and even concussions. These injuries can be fatal if they occur in vital areas of the body, such as the head or chest.
10K
  • Mechanical Engineering
  • Other Physics Topics
13K
9K
  • Classical Physics
  • Biology and Medical
  • Materials and Chemical Engineering
