Length of an infinite square well?
The discussion centers on the relationship between the length of an infinite square well, denoted as 'a', and the probability of measuring the ground state energy, E_1. The initial wavefunction provided is \Psi(x,0) = Ax for (0 ≤ x ≤ a/2) and \Psi(x,0) = A(a-x) for (a/2 ≤ x ≤ a). It is concluded that as 'a' approaches infinity, the probability of finding the particle in the ground state energy level approaches approximately 0.986. However, a counterpoint is raised regarding the normalization of the wavefunction, suggesting that the probability should be independent of 'a'.
  • Understanding of quantum mechanics concepts, specifically infinite square wells.
  • Familiarity with wavefunctions and their normalization.
  • Knowledge of energy levels in quantum systems.
  • Basic mathematical skills for handling limits and probabilities.
  • Study the normalization of wavefunctions in quantum mechanics.
  • Explore the implications of wavefunction length on energy state probabilities.
  • Investigate the mathematical derivation of probabilities in infinite square wells.
  • Learn about the physical interpretation of quantum states in relation to well dimensions.
Students of quantum mechanics, physicists analyzing wavefunctions, and educators teaching concepts related to infinite square wells and energy measurements.
*melinda*
Actually, this is more of a general question relating to a homework problem I already did. I was given the initial wavefunction of a particle in an infinite square well:
[tex]\Psi(x,0) = Ax[/tex] if [tex](0 \leq x \leq \frac{a}{2})[/tex], and [tex]=A(a-x)[/tex] if [tex](\frac{a}{2} \leq x \leq a)[/tex]
And of course [tex]\Psi(0,0) = \Psi(a,0) = 0[/tex]
I was asked to find [tex]\Psi(x,t)[/tex] , which I did, and I was also asked to find the probability that "a measurement of the energy would yield the value [tex]E_1[/tex]", the ground state energy, which I also did. However, this probability is dependent on the length of the well, given by 'a'.
I was curious about this, and I found that the probability that "a measurement of the energy would yield the value [tex]E_1[/tex]" increases as the value of 'a' increases.
Taking the limit as 'a' approaches infinity gives a probability of finding the energy in the ground state to be approx. 0.986, which means that there is a non-zero probability of finding the particle in another energy level.
OK, as far as I can tell for a given wavefunction, increasing the length of the infinite square well increases the probability of finding the particle in the lowest energy state. Mathematically I understand this, but I am still lacking physical intuition about what is actually happening when the length of the well increases.
So, for a given wavefunction, WHY does increasing the length of the infinite square well increases the probability of finding the particle in the lowest energy state?
Thanks, I hope this question makes sense!
*melinda*
Are you sure? Did you normalize the wavefunction properly?
The probability is a dimensionless number: but a is a length, and it is the only length in the problem here: there is no way to make a dimensionless number that depends on a. So I'd think, without actually calculating anything, that the probability to find E_1 should be independent of a.
  • · Replies 39 ·
16K
  • · Replies 16 ·
