Work on Block with an opposing force
The discussion revolves around calculating the work done on a block by two opposing forces acting on it while it moves along a frictionless surface. The forces in question are F_1 = 75.0 N and F_2 = 20.0 N, and the block moves from an initial position of x_i = -1.00 cm to a final position of x_f = 2.00 cm.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the work formula W = F * d, noting that initial attempts to use this formula did not yield correct results. There is confusion regarding the relevance of angles and vector components in this context, especially since the forces are described as acting parallel to the displacement.
There is an ongoing exploration of the correct application of the work formula, with some participants suggesting that careful consideration of angles is necessary. The discussion reflects a lack of consensus on the correct approach, as participants express uncertainty about the implications of the hint regarding vectors.
Participants note that the problem may involve hidden complexities related to vector directions, despite the forces being parallel to the displacement. The original poster has expressed difficulty in understanding how to apply the work formula correctly given the provided hints.
Ltcellis
Two forces, of magnitudes F_1 = 75.0 N and F_2 = 20.0 N, act in opposite directions on a block, which sits atop a frictionless surface, as shown in the figure. Initially, the center of the block is at position x_i = -1.00 cm. At some later time, the block has moved to the right, and its center is at a new position, x_f = 2.00 cm.
Find the work W_1 done on the block by the force of magnitude F_1 = 75.0 N as the block moves from x_i = -1.00 cm to x_f = 2.00
Do the same for W_1 by force of magnitude F_2 = 20
W= F d
Since it's already parallel no need for cos
Well, apparently I found out that F * d does not give the correct answer. I also tried subtracting one force or one resultant work from the other but it still isn't correct. The hint that is given to us has something to do with vectors and angles but I don't see how that will apply since the force is already parallel to the surface distance. Is there something hidden that I'm missing? Any thoughts?
Thanks
W= F d
Thanks
F.d should work if applied correctly. Perhaps if you showed more detail we could help you out.
Well the only thing I can add on is the diagram
Other than that, all that I said is all the information given.
The hint says something like this :
The work W done by a force F_vec in producing a displacement s_vec is given by
W = \vec{F} * \vec{s} = \\vec{F} *\vec{s} *\cos{\phi},
where \vec{F}\ and \\vec{s}\ are the magnitudes of \vec{F} and \vec{s} respectively, and phi is the smaller angle between the two vectors.
The only thing is, I don't see how an angle is applied if the forces are already parallel.
I tried F * d but it says its incorrect.
I'll say again, you can apply W=Fd here provided that you apply it correctly.
You need to be careful with the angles. Are both the forces applied parallel to the displacement?
  • · Replies 35 ·
