How to Design an Efficient DIY Propeller for a Homemade Car?
  • Thread starter Thread starter goorioles747
    Home Propeller
This discussion focuses on designing an efficient DIY propeller for a homemade car using materials like soda bottle plastic or cardstock. Key concepts for propeller efficiency include camber, which involves curving the blades to redirect airflow, and twist, which ensures a steeper angle of attack at the center compared to the tips. Implementing these design principles will enhance the propeller's ability to generate sufficient power for movement.
  • Understanding of propeller design principles
  • Knowledge of airflow dynamics
  • Familiarity with materials like soda bottle plastic and cardstock
  • Basic mechanics of rubber band propulsion
  • Research advanced propeller design techniques
  • Explore the effects of camber on propeller performance
  • Learn about the mechanics of rubber band-powered vehicles
  • Investigate materials optimization for lightweight propellers
This discussion is beneficial for hobbyists, DIY enthusiasts, and educators interested in aerodynamics, mechanical design, and propulsion systems for small-scale vehicles.
goorioles747
Hi,
I need to make a propeller using either soda bottle plastic or cardstock. I think I can come up with a mechanism to spin it with a rubber band, but, I need an efficient propeller that creates enough power to move the car I am building. Any ideas/possible designs?
Two concepts are critical to propeller efficiency:
-Camber: The propeller blades have to be curved to re-direct the airflow.
-Twist: The propeller blade has to be twisted to provide a steeper angle of attack at the center than at the tips (the tips are almost flat in the direction it spins). this is so that the velocity distribution along the blad is constant.
  • · Replies 39 ·
