Thread Closed
Linear Algebra - Determinants
Share Thread
Oct10-08, 10:13 PM   #1
If [tex]det\left[
\begin {array}{ccc}
a&1&d\\
\noalign{\medskip}
b&1&e\\
\noalign{\medskip}
c&1&f
\end {array}
\right]=-4
[/tex] and [tex]det\left[
\begin {array}{ccc}
a&1&d\\
\noalign{\medskip}
b&2&e\\
\noalign{\medskip}
c&3&f
\end {array}
\right]=-1
[/tex],
then [tex]det\left[
\begin {array}{ccc}
a&8&d\\
\noalign{\medskip}
b&8&e\\
\noalign{\medskip}
c&8&f
\end {array}
\right]=___
[/tex]
and [tex]det\left[
\begin {array}{ccc}
a&-1&d\\
\noalign{\medskip}
b&-4&e\\
\noalign{\medskip}
c&-7&f
\end {array}
\right]=___
[/tex]
3. The attempt at a solution
For the first question, I'm pretty sure that I can factor out an 8 as it is a scalar multiple of the second column. One of the properties of determinants is that if a row or column is multiplied by a scalar, then we can factor the scalar out and then multiply the determinant by that scalar. Thus, the answer would be -32.
However, I am really stumped by the second question. I am sure that the scalar -1 is somehow multiplied into the matrix, but I am not sure how the numbers were obtained. I'm thinking that each row must have resulted from the scalar multiple of another row. However, if that's the case, then why are the unknowns unaffected?
I am seriously at my wit's end and any direction would be helpful.
Thank you!
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Oct10-08, 10:57 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
(-1,-4,-7) is (-3)*(1,2,3)+2*(1,1,1). A determinant is a linear function of each of it's columns.
Oct10-08, 11:10 PM   #3
Recognitions:
Note that detA = detA^T. And also the determinant of A+B where A,B differ by a single row is det(A+B). Now multiply the column 1,2,3 of that matrix by 3. What do you have to multiply the 2nd column of the 1,1,1 column matrix such that adding up both gives you -1,-4,-7?
Oct10-08, 11:27 PM   #4
Wow! It makes so much more sense now that you've mentioned detA=detA^T to me! Thank you so much!
Oct10-08, 11:37 PM   #5
Now that you have already seen the algebraic explanation, here is an image tutorial showing the geometric intuition behind it:
http://img137.imageshack.us/img137/6...trowopsjx2.png
The image explains in 2D, but in higher dimensions everything is the same except parallelograms become paralellipipeds and the determinant measures volume not area.
Can you see why the determinant of a singular matrix has to be zero?
Oct11-08, 12:25 AM   #6
Recognitions:
Uh, what has that got to do with the OP's question?
Oct11-08, 01:43 AM   #7
It is a visual proof that
1) Multiplying a column by a constant scales the determinant by that constant, and
2) The determinant is linear in any particular column.
Thread Closed
Similar discussions for: Linear Algebra - Determinants
Thread Forum Replies
Linear Algebra: Linear Transformation and Linear Independence Calculus & Beyond Homework 8
linear algebra: determinants (proof) Calculus & Beyond Homework 1
Linear Algebra question: n x n determinants Calculus & Beyond Homework 10
linear algebra, determinants, and transposes Introductory Physics Homework 5
linear algebra: determinants and eigenvalues Linear & Abstract Algebra 15
