New Reply
Magnetic Field of Magnetic Dipole Moment
Share Thread Thread Tools
Oct11-08, 10:51 AM   #1
I'm seeking some clarification on a topic found in Jackson 'Classical Electrodynamics' Chapter 5. This deals with the magnetic field of a localised current distribution, where the magnetic vector potential is given by
[tex]\vec{A}(\vec{x}) = \frac{\mu_0}{4\pi} \frac{\vec{m}\times\vec{x}}{\left|\vec{x}\right|^3}[/tex]
and the magnetic induction [tex]\vec{B}[/tex] is the curl of this [tex]\vec{B} = \nabla \times \vec{A}[/tex].
I know that the end result should be
[tex]\vec{B}(\vec{x}) = \frac{\mu_0}{4\pi} \left[\frac{3\vec{n}\left(\vec{n}\cdot\vec{m} - \vec{m}}{\left|\vec{x}\right|^3}\right][/tex]
Where [tex]\vec{n}[/tex] is the unit vector in the direction of [tex]\vec{x}[/tex]
But I'm struggling to do this calculation for myself.
I know that
[tex]\vec{B}(\vec{x}) = \frac{\mu_0}{4\pi} \left(\nabla \times \left(\frac{\vec{m}\times\vec{x}}{\left|\vec{x}\right|^3}\right)\right) \\
= \frac{\mu_0}{4\pi}\left(\vec{m}\left(\nabla\cdot\frac{\vec{x}}{\left|\v ec{x}\right|^3}\right) - \frac{\vec{x}}{\left|\vec{x}\right|^3}\left(\nabla\cdot \vec{m}\right)\right)[/tex]
How does Jackson end up at the result quoted?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Oct11-08, 01:48 PM   #2
Recognitions:
Your second term is wrong. It should be
[tex]-({\vec m}\cdot\nabla)\left[\frac{\vec x}{|{\vec x}|^3}\right][/tex].
Apr4-09, 07:45 AM   #3
Hi
I'm new to this forum! Googleing for the questioned problem I found this forum. Having the same problem as the author of this thread, I want to ask if someone has a solution on how Jackson found the formula for [tex]\vec{B}[/tex]?
I tried my luck with the product rule [tex]\nabla\times(\vec{A}\times\vec{B})=(\vec{B}\cdot\nabla)\vec{A}-(\vec{A}\cdot\nabla)\vec{B}+\vec{A}(\nabla\cdot\vec{B})-\vec{B}(\nabla\cdot\vec{A})[/tex] but came to no conclusion.
kind regards,
derivator
(sorry for my english, it's not my mother tongue)
Apr4-09, 04:25 PM   #4
Recognitions:
As I said in my post, the curl of the cross product should be
= \frac{\mu_0}{4\pi}\left(\vec{m}\left(\nabla\cdot\frac{\vec{x}}{\left|\v ec{x}\right|^3}\right) - ({\vec m}\cdot\nabla)\left[\frac{\vec x}{|{\vec x}|^3}\right][/tex].
This follows because m is a constant so only two terms of your four enter.
Given this result, the first term is a delta function is not needed if r>0.
The second term gives the result in the first post if the delta function singularity at the origin is again ignored.
Jackson is a bit obscure on this.
Apr4-09, 05:14 PM   #5
Hi,
thanks for your answer.
Could you get a bit more detailed on how to show that
[tex]- ({\vec m}\cdot\nabla)\left[\frac{\vec x}{|{\vec x}|^3}\right]=\left[\frac{3\vec{n}\left(\vec{n}\cdot\vec{m}\right) - \vec{m}}{\left|\vec{x}\right|^3}\right][/tex]
is correct?
Apr5-09, 10:58 AM   #6
Recognitions:
You really need a better textbook.
Sorry I can't seem to find my latex error below. If hyou can read or correct it, it should show you what to do.
-{\vec x} ({\vec m}\cdot\nabla)\frac{1}{|{\vec x}|^3}
-\frac{1}{|{\vec x}|^3} ({\vec m}\cdot\nabla){\vec x}
Apr5-09, 11:10 AM   #7
Recognitions:
The point is that the m.del acts on only one function at a time.
Mar22-11, 03:58 AM   #8
[tex]
- (\vec{m}\cdot\nabla)\left[\frac{\vec{x}}{|\vec {x}|^3}\right]=
[/tex]
Mar22-11, 05:38 AM   #9
Quote by Derivator View Post
Hi,
is correct?
[tex]\nabla\frac{\vec{r}}{r^{3}}=\left(\nabla\frac{1}{r^{3}}\right)\vec{r}+\ frac{\nabla\vec{r}}{r^{3}}=-\frac{3\vec{r}\vec{r}}{r^{5}}+\frac{\mathbf{I}}{r^{3}}[/tex]
[tex]\vec{m}\cdot\nabla\frac{\vec{r}}{r^{3}}=\vec{m}\cdot\left(-\frac{3\vec{r}\vec{r}}{r^{5}}+\frac{\mathbf{I}}{r^{3}}\right)=-\frac{3(\vec{m}\cdot\vec{r})\vec{r}}{r^{5}}+\frac{\vec{m}}{r^{3}}[/tex]
I is the unit tensor.
New Reply
Thread Tools
Similar Threads for: Magnetic Field of Magnetic Dipole Moment
Thread Forum Replies
Magnetic dipole in an external magnetic field General Physics 3
why is the electric dipole moment of an atom zero, but the magnetic moment nonzero? Quantum Physics 9
Question about a magnetic dipole in an inhomogeneous magnetic field.Please help ASAP Advanced Physics Homework 3
deriving the energy of a magnetic dipole in a magnetic field Introductory Physics Homework 8
deriving the energy of a magnetic dipole in a magnetic field Classical Physics 1
