Span and Subspace Question
by kbartlett
Tags: span, subspace
kbartlett
kbartlett is offline
#1
Oct13-08, 01:10 PM
P: 2
I got a small test tomorrow and i have been working throu exercises but i can't seem to solve this question:
Let V be a vector space over a field F, and let [tex]S\subset S'[/tex] be subsets of V.
a) Show that span(S) is a subspace of V.
b) Show that span(S) is a subset of Span(S').
c) Take [tex] V = R^3 [/tex] and give an example to show that it is possible that Span(S) = Span (S') even though [tex] S \subset S'[/tex] and [tex] S \neq S' [/tex].
d) Let U,W be subspaces of V. Prove that U+W is also a subspace of V.
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
Tac-Tics
Tac-Tics is offline
#2
Oct13-08, 03:10 PM
P: 810
Quote Quote by kbartlett View Post
Go back to your definitions of subspace and span. These problems become pretty easy when you do.
A subspace is a subset of a vector space which is still closed under addition and scalar multiplication. Stated another way, any linear combination of vectors in S will be in S (or of S' in S').
The span is simply the set of linear combinations of a set of vectors. That is, you can take any finite number of vectors from S, make them as long or as short as you want, and add them together and the result is always in Span(S).
For the proof of (d), I'm not sure of your use of + in U+W. U and W are sets, which we don't usually have an addition operation for. Maybe you meant U union W or maybe you're using a notation I'm just not familiar with or something.
(Also, use the [tex ] tag, not [math ] on these boards. The latter doesn't work.
CompuChip
CompuChip is offline
#3
Oct13-08, 03:19 PM
Sci Advisor
HW Helper
P: 4,301
Welcome to PF kbartlett. Instead of "math", you may want to try "tex"
It seems to me that a) and b) are the same question, if you replace S by V and S' by S in b).
Try writing down an element from span(S) which is not in V, and use the axioms of a vector space to derive a contradiction.
For c: try to make S a set that spans the plane [tex]\mathbb R^2[/tex]. Do you see how to construct S'?
For d: check the axioms of a vector space.
If you need more specific advise, please post some workings.
CompuChip
#4
Oct13-08, 03:21 PM
Sci Advisor
HW Helper
P: 4,301
Quote Quote by Tac-Tics View Post
As U and W are subspaces of a vector space (which has an addition [itex]+_V[/itex]), I think it is not unreasonable to assume that
[tex]U + W = \{ u +_V w \mid u \in U, w \in W \}[/tex]
kbartlett
#5
Oct14-08, 05:29 AM
P: 2
Thanks i think ive got the answer to part d), but im still stuck on the rest.
CompuChip
#6
Oct14-08, 06:31 AM
Sci Advisor
HW Helper
P: 4,301
Suppose that I tell you that some vector, v, is in Span(S). What does this mean?
Register to reply
Related Discussions
Subspace, span Calculus & Beyond Homework 5
subspace question Linear & Abstract Algebra 1
a question about span Calculus & Beyond Homework 0
Prove span(S1 U S2) = span(S1) + span(S2) Calculus & Beyond Homework 10
Question on definition of Span Calculus 2
