Spring / constant applied force question
A block with a mass of 0.5 kg is attached to a spring with a spring constant of 40 N/m on a frictionless table. A constant horizontal force of 20 N is applied, causing the spring to stretch. To determine the speed of the block after it has moved 0.25 meters, one must analyze the forces acting on the block, including the applied force and the spring force, and apply the work-energy principle to calculate the kinetic energy remaining after accounting for the potential energy stored in the spring.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of Hooke's Law for springs
  • Familiarity with work-energy principles
  • Ability to draw and interpret free body diagrams
  • Study the application of Hooke's Law in dynamic systems
  • Learn about the work-energy theorem in physics
  • Explore free body diagram techniques for multi-force systems
  • Investigate the relationship between kinetic and potential energy in mechanical systems
Students of physics, mechanical engineers, and anyone interested in understanding the dynamics of systems involving springs and applied forces.
kennien
Hi
A block ( 0.5 kg ) is attached to a spring ( k = 40N/m ) on a frictionless table..
The spring is 0.6 meter long unstretched ..
A constant force (20 N ) is applied horisontaly causing the spring to stretch
1) question : what is the speed/velocity of the box after 0.25 meter ?
can anyone help me with this ?
I understand that the box accelerates according to F=ma in the beginning , but when the spring starts to exert force in the other direction , that's when I am loosing it
draw a free body diagram of the box when both your external force and the spring are acting on it. The diagram stays the same, even though the force of the spring changes as a function of position. Use this diagram to find F as a function of x. I'd personally approach this as a work/energy problem... using the expression for force and integrating that expression over the path of motion. then you know the energy into the system. Any energy NOT converted to potential energy in the spring remains as kinetic energy, which you can use to find speed.
