| Thread Closed |
Two heat transfer questions (fins) I am unsure of |
Share Thread | Thread Tools |
| Oct15-08, 01:47 PM | #1 |
A fin is 80% efficient. Which design change would improve the heat transfer the most, assuming all other variables were held constant? (a) double the number of fins (b) double the length of the fins (c) find a new material with twice the conductivity (d) double the heat transfer coefficient 2. Relevant equations No = 1 - NAf/At (1-Nf), where N is number of fins, Af is area of fin, At is area of primed surface, Nf is efficiency of single fin Nf = qf/hAf(Tb-T*), where qf is heat transfer rate of fin, Tb is temperature of fin base, and T* is the ambient temperature 3. The attempt at a solution increasing the number of fins definitely improves the heat transfer rate, but if you add too many the spacing between fins becomes small and flow is impeded doubling the length of the fins also increases efficiency, but there is an upper limit (2.65/m), where m = sqrt(hP/kAc), beyond which improvement is not very significant doubling the heat transfer coefficient (h) is not always practical, depending on the power required to force air at velocity v through the system So I want to say the answer is (c).....? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Two heat transfer questions (fins) I am unsure of
| Simple but unsure, compound questions | Introductory Physics Homework | 7 | ||
| Unsure of major as well as wanting to transfer universities (California) | Academic Guidance | 0 | ||
| heat transfer & sound transfer | General Physics | 0 | ||
| Do fins help an object rotate? | General Physics | 5 | ||
| rate of heat transfer and heat conductors | General Physics | 3 | ||
