What Force is Needed to Double the Constant Velocity of a Block?
  • Thread starter Thread starter snoopygal327
    Laws
The discussion revolves around the forces acting on a block moving on a flat surface and the implications of changing its velocity. Participants explore the relationship between applied force, friction, and acceleration in the context of Newton's laws of motion.
  • Participants discuss the initial applied force and its relationship to friction when the block moves at a constant velocity. There is questioning about whether increasing the applied force would also increase friction and how that affects the block's ability to reach a higher constant velocity. Some participants reflect on the implications of Newton's third law in a scenario involving two individuals pushing against each other.
The discussion is ongoing, with participants sharing insights about friction and its behavior with respect to velocity. There is a recognition that additional force beyond what is needed for constant motion would lead to acceleration, and some participants are considering the implications of maintaining a new constant velocity after acceleration.
Participants are navigating assumptions about friction and the effects of applied forces in a homework context, with some uncertainty about the relationship between force, velocity, and friction in their scenarios.
snoopygal327
A force of 1.5 N is applied to a block on a flat surface and the block moves with a constant velocity. Approximately what applied force is needed to keep the block moving with a constant velocity that is twice as large as before?
F = ma
At first I thought the answer would be 3 N, but now I'm not sure. When you originally apply the force of 1.5 N the force of friction must be 1.5 N as well so that the block moves with a constant velocity right? So then if you increase the force to 3 N would friction increase to 3 N so that the block moves with a constant velocity?
2)
A 90 kg man and a 60 kg boy each have one hand extended out in front and are pushing on each other. Neither is moving. Eventually the boy begins to slide across the floor. Compare the forces between their hands.
None?
When neither is moving the forces between their hands are equal according to Newton's third law. But once they start moving does this still hold true? My guess is that the forces are still equal but have increased in magnitude so that's what causes the boy's acceleration.
Recall the general formula for friction force. How does it change (or does it) when velocity is doubled?
(2)
I agree with your answer.
p.s. Welcome to PF.
Okay, I remember now that friction force doesn't increase with velocity. In that case, pulling with a force of 3 N would cause acceleration. Then is it even possible to move the block with twice the constant velocity?
Yes. Any excess of force over the constant motion state of 1.5N will serve to accelerate the block. Once at double the speed how much force is required to maintain it at that speed?
Oh so does that mean that after the block has accelerated, you only need to apply a force of 1.5 N to keep it moving at twice the constant velocity?
If there was more it would accelerate no?
If less it would slow.
Looks like it to me.
Thank you!
  • · Replies 16 ·
