Nimonic 115 Nickel Alloy: Poisson's Ratio
  • Thread starter Thread starter everybody
    Metal Properties
The discussion revolves around finding the Poisson's ratio for Nimonic 115, a nickel-based alloy, particularly in the context of its application as a turbine blade material. Participants explore potential sources for this information and consider alternatives if data is unavailable.
  • Exploratory, Technical explanation, Debate/contested
  • One participant expresses difficulty in finding the Poisson's ratio for Nimonic 115 and indicates a need for this information for research purposes.
  • Another participant suggests contacting the supplier for technical information, noting that manufacturers may not have specific data but could provide estimates based on similar alloys.
  • A participant questions whether the original inquiry might be referring to Multimet N-155 instead of Nimonic 115.
  • One participant emphasizes the importance of obtaining the correct data for Nimonic 115, indicating a willingness to consider alternative materials if necessary.
  • Another participant recommends contacting Special Metals, the originator of the alloy, for assistance from an applications engineer.
Participants do not reach a consensus on the availability of the Poisson's ratio for Nimonic 115, and multiple suggestions for obtaining information are presented without resolution.
There is uncertainty regarding the availability of specific material properties for Nimonic 115, and the discussion includes references to alternative alloys and the potential need for further research.
everybody
do anyone knows how to find poisson's ratio of nimonic 115 nickle based alloy?i try google it can't found it::frown:.It took me two hours for nothing..
Call however you are buying it from?
I don't have any materials references that specific - it might also be that the makers don't have a value for that alloy but might know that it's not too different from another alloy.
Are you perhaps referring to Multimet, N-155 (in stead of 115)?
no,i want nimonic 115 like in this url http://www.suppliersonline.com/propertypages/Nimonic115.asp"
I have chosen this material to be my turbine blade material.If this material don't have available data of poisson ratio,i consider to change to other material which have its data and perhaps better than this material.DO you have any suggestion?
i don't want to buy it.i just want it for my research
  • · Replies 19 ·
