Sound to travel form the TV to the viewer
  • Thread starter Thread starter zeshkani_usa
    Form Sound Travel
The problem involves a scenario where a celebrity's press conference is televised, and a viewer hears the sound from the television set while a reporter hears it directly from the celebrity. The viewer is seated at a specific distance from the TV, and the reporter is at a different distance from the microphone. The objective is to determine the maximum distance between the viewer and the celebrity using the speed of sound.
  • Participants discuss the relationship between the times it takes for sound to travel to the viewer and the reporter. There is confusion regarding whether to add or subtract these times. Some participants question the approach of combining the times and suggest that the difference might be more relevant.
The discussion is ongoing, with participants exploring different interpretations of the time relationships involved. Some guidance has been offered regarding the calculations needed to find the correct answer, but there is no explicit consensus on the correct approach yet.
Participants note that the reporter and viewer hear the sound simultaneously, which is a critical aspect of the problem. There are also references to specific equations and relationships that need to be established based on the problem's parameters.
zeshkani_usa
A celebrity holds a press conference, which is televised live. A television viewer hears the sound picked up by a microphone directly in front of the celebrity. This viewer is seated 2.9 m from the television set. A reporter at the press conference is located 5.2 m from the microphone and hears the words directly at the very same instant that the television viewer hears them. Using a value of 343 m/s for the speed of sound, determine the maximum distance between the television viewer and the celebrity.
Let the time required for the sound to travel form the TV to the viewer be t1 = d1/v, where the symbols have their usual meaning. Let the time required for the sound to travel from the celebrity to the reporter be t2 = s2/v . The time required for the EM wave to travel to the viewer's set is t = s/c . Using the information given in the problem statement, construct a relationship between these three times.
t1 = 8.45e-3 sec
t2 = 1.50e-2 sec
so should t = t1 + t2
then t1 + t2 = s/ 3.00e8 then just solve for s , i did solve for s this way but its wrong
t1 = 8.45e-3 sec
t2 = 1.50e-2 sec
Why have you added the times together?
Isn't the difference what you're interested in?
even adding or subtracting , its still the wrong asnwer
There is no adding to get to the right answer.
Isn't time * velocity the distance though?
You have to divide the distances / speed of sound to get the two times, subtract, then multiply by speed of light.
remember: the reporter hears the sound at the exact same time as the viewer. you have to adjust the equation for the time that it takes both individuals to hear the sound and then adjust for the viewer who is "seeing" it.
d1/343 = t1
d2/343 = t2
(t1-t2) x 3e8
----exact same problem on hw...got it right.
9K
14K
  • · Replies 16 ·
15K
12K
