| Thread Closed |
Why do Jet Engines Have a Compressor? |
Share Thread | Thread Tools |
| Oct17-08, 09:33 PM | #1 |
So like it says. It may be a silly question, but I am doing some reading on jet engines (on Wiki) and I am having trouble finding an explanation as to why we want to increase the pressure of the air before it goes into combustion. Does this just another way of increasing the thrust?
Thanks, Casey |
| Oct17-08, 09:57 PM | #2 |
That is actually a very good question. In the following link an attempt is made in answering this very basic question.
http://www.aerospaceweb.org/question...on/q0033.shtml The main reason given in the link above is quote: "If uncompressed, the air-fuel mixture won't burn and the engine can't generate any thrust". As a combustion engineer I don't like this explanation (the German V1 rocket did not have a compressor I believe). I see no reason why a fuel air mixture uncompressed would not burn. The whole idea behind a jet engine is that you accelerate the fluid going through it with as driving force a pressure gradient. The pressure in a jet engine is the highest right after the last stage of compression (for axial compressors). The combustion then takes place with minimum pressure loss and the the expansion begins through the turbines and finally through the nozzle . The high pressure created by the compressor forces the fluid to go out through the back. In other words, it creates the favorable pressure gradient used to accelerate the flow and produce thrust. By drawing out a Brayton cycle you can also show the effect this has on the efficiency. |
| Oct18-08, 02:47 AM | #3 |
Good post. The V1, though, used a valved pulse-jet. Compression wasn't needed because the valves closed off the front of the combustion chamber upon firing. That made it essentially a rocket.
| Oct18-08, 03:06 AM | #4 |
For the same reason you get better power out of an internal combustion engine with a higher compression ratio. This is really a question in thermodynamics.
Danger, the buzz bomb used a tuned exhaust. After the exhaust had pulsed out the back, the low pressure returned a portion of it to toward the combustion chamber. This compressed the air fuel mixture that had entered during the low pressure phase. |
| Oct18-08, 09:15 AM | #5 |
I would say the main reason for the compressor is power density in any engine.
| Oct18-08, 09:33 AM | #6 |
Subsequent designs capitalized upon that feature, and eventually the valve box was eliminated when people figured out how to properly tune the system so the pulses effectively closed the front of the chamber through pressurization. The reason that the V1 was called the 'buzz bomb' was because of the noise made by the intake valves flapping. |
| Oct18-08, 10:05 AM | #7 |
Casey, a compressor on a jet engine prevents back-flow and it acts like a supercharger on a car's IC engine, delivering an increased load of oxygen so that more fuel can be burned more efficiently.
| Oct18-08, 12:08 PM | #8 |
Admin
Thrust comes from the mass flowrate and velocity. The compressor increases the pressure of the atmosphere and momentum of the air flow. The air (oxidizer) combines with the fuel, which burns and provides energy to the flow. The combusion does two things - the combutsion process breaks fuel molecules to make more molecules and provides heat which increases the temperature which decreases the density which causes an increase in velocity of the flow. The compressor 'pushes' the flow into the combusion chamber, and the flow passes out the exhaust with a much high velocity than it entered - and that combined with the mass increase from the fuel - causes the thrust. Think of the continuity (mass flow) equation. Mass flow in = mass flow out, otherwise the mass in the control volume (jet engine) would increase or decrease. The momentum equation: momentum out > momentum in, and the change in momentum gives the thrust (force). Energy (in flow) equation: Work-Energy out = work in + energy (thermal) produced |
| Oct19-08, 02:29 PM | #9 |
In addition to all those excellent answers, there is also the air density problem. The higher the flight, the less dense the atmosphere, the less drag and the least fuel to be used. But at those densities there is not a lot of oxygen to burn and we really need high compression rates to sustain a nice little flame in that engine.
| Oct22-08, 08:32 AM | #10 |
| Oct22-08, 11:20 AM | #11 |
Recognitions:
To initiate flow, there has to be a favorable pressure graidient in the engine. The compressor's job isn't to make sure it keeps flow moving in a certian direction, although most of the time it does that as a by product of increasing the density (although in surge it definitely stops doing that). Also, as Jaap pointed out, the idea that an air-fuel mixture wouldn't burn uncompressed is just silly. The whole point is that thrust is directly proportional to the mass flow through the engine. The more mass flow, the more thrust. |
| Oct22-08, 01:04 PM | #12 |
| Oct22-08, 01:16 PM | #13 |
| Oct22-08, 01:39 PM | #14 |
Like I said, this is question in thermodynamics.
In a jet turbine engine, a 4 cycle gasoline engine, diesel, or coal dust turbine an element of combustable fluid goes through a process of compression, ignition and expansion to obtain work. I could find a believable answer that gave power efficiency as a function of pressures. What's the power efficiency ratio of a compressed vs. uncompressed working fluid? Is it 4 to 1, 5 to 1, twenty to 1? |
| Oct22-08, 02:37 PM | #15 |
Recognitions:
From a thermo point of view, the cycle efficiency is directly tied to the compressor's pressure ratio. The propulsive efficiency drops off as pressure ratio increases but the thermal efficiency increases with pressure ratio. This makes the overall efficiency increase with pressure ratio. If you look through some literature like Hill and Peterson, you can see plots of this very topic that illustrate this point.
| Oct22-08, 03:15 PM | #16 |
Admin
Simple thought experiment - we have a mixtures of oxygen and fuel of varying densities. On the one end we have mixture that we know will burn, on the other end we have vacuum (wih only traces of oxygen and fuel) - same mixture, but it will not burn. Somewhere in the middle must be the point where we move from "burning" to "not burning". |
| Oct23-08, 04:30 AM | #17 |
The efficiency of an Otto cycle, eta is given as [tex] \eta = 1 - \left( \frac{V_{top}}{V_{bottom}} \right) ^{0.27}[/tex] as given in this link, http://courses.washington.edu/me341/oct22v2.htm that I can't generate a hyperlink for. A volumetric compression ratio of 12 spits out 49% efficiency. A ratio of one gives zero, which makes no sense, or course. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why do Jet Engines Have a Compressor?
| small engines vs. big engines? | General Engineering | 75 | ||
| CFD in Air compressor | Mechanical Engineering | 2 | ||
| air compressor | General Physics | 2 | ||
| Compressor Oil | Mechanical Engineering | 4 | ||
| Air Compressor Oil | Mechanical Engineering | 3 | ||
