Differential Equation Roadblock
The differential equation yy'(1+x²) - x(1+y²) = 0 with the initial condition y(0) = √3 is a separable differential equation. The initial attempt incorrectly assumed y' = 0, leading to the erroneous solution y = x + √3. The correct approach involves separating variables, resulting in the solution y = √(4x² + 3). This solution satisfies the initial condition and correctly represents the relationship between y and x.
  • Understanding of differential equations, specifically separable equations.
  • Familiarity with initial value problems and their solutions.
  • Knowledge of integration techniques and their applications in solving differential equations.
  • Basic algebra skills for manipulating equations and solving for constants.
  • Study the method of separation of variables in differential equations.
  • Learn about initial value problems and their significance in differential equations.
  • Explore integration techniques relevant to solving differential equations.
  • Review examples of separable differential equations to reinforce understanding.
Students studying calculus, particularly those focusing on differential equations, as well as educators looking for examples of solving initial value problems.
jinksys
Find the solution of the differential equation yy'(1+x2)-x(1+y2)=0 if y(0)=Sqrt(3)
I let y=Sqrt(3) and x=0 and solve for y'.
y'=0
Integrate both sides.
y=x +c
Plug my points into find C
Sqrt(3)=0 +c
C=Sqrt(3)
My solution is y=x+Sqrt(3).
Check:
Plug x+Sqrt(3) in for y, and 1 for y' into the DE.
End up with Sqrt(3)=0, so somewhere I went wrong.
Any help appreciated, Thanks.
y'=0
y=x +c
Sqrt(3)=0 +c
C=Sqrt(3)
Check:
You are confusing y(0) with y(x). y(0) represents the y-value when x = 0. y(x) represents the y-value for an arbitrary x-value. If you were to plot the graph of y as a function of x, all you know is that the graph goes through (0, sqrt(3)).
y'=0
y=x +c
How did you get y' = 0? This would have been correct if y(x) = sqrt(3). IOW if the graph of y were a horizontal line sqrt(3) units above the x-axis.
If it were true that y' = 0 (it actually isn't true, though), how did you get y = x + c? If you integrate 0 with respect to x, you don't get x + C.
The DE you are given is a separable DE. That means it is possible to get all of the things that involve y (including dy) on one side, and all of the things that involve x (and dx) on the other side. That's the approach you should take with this problem.
Thanks for your help.
I got it now, y=Sqrt( 4x2+3 )
I don't know why I thought the integral of 0 with respect to X was x :rolleyes:
  • · Replies 21 ·
